springs
Old Mar 2, 2003 | 02:48 AM
asloudasitgets's Avatar
springs
how come when people ask or talk about springs no one ever mentions shocks?
if you get springs dont you neeed the aftermarket shocks?
Old Mar 2, 2003 | 05:50 AM
SimTypeS's Avatar
...and then there was One
Not right away. 40K miles down the roads, maybe.
Old Mar 2, 2003 | 09:25 AM
Tom Blasing's Avatar
is the Mighty Favog
If your dealing with aftermarket springs and they are of the "lowering" variety then, yes, different shocks are needed. Ones that have a shorter stiffer travel.
I your replacing stock length springs (non-lowering) with the same ride height then a stock shock will be fine. But, yes, they will (like everything else) were out; both stock and aftermarket.
All the shocl does is keep the tires planted on th epavement as long as possible through bound and rebound. They also keep the car from bouncing continually after the spings have been flexed. The springs keep the car from bottoming out over bumps and absorb the more abrupt pavement changes.
So the springs absorb the bump and the shocks settle the spring down after it does.
Eternal TL2k3's Avatar
now is that 40k AFTER putting on the springs or just ~40k?
Old Mar 2, 2003 | 10:44 AM
LiQiCE's Avatar
Liquid Ice
I'm interested in this too ... I'm probably gonna be getting CompTech Springs to lower my car just a tad and am wondering if I should be putting Koni shocks on my car at the same time, or if I can wait awhile (Only 7800 miles on the car now though)
Old Mar 2, 2003 | 10:55 AM
jkozlow3's Avatar
You should be fine with the stock shocks.
Old Mar 2, 2003 | 06:18 PM
SimTypeS's Avatar
Your stock shocks are good for how long with your stock springs? When would you replace them? ~100K miles? So, if you put lowering springs on your car and it already has 50K miles on it, I would replace the shocks at the same time. If your car only has 20K miles on it, you probably wouldn't 'need' to.
Old Mar 2, 2003 | 06:42 PM
this is me's Avatar
Interesting.
My car will be about 7k miles this spring and i'm thinking about lowering it so i dun need to change anything rite?
Old Mar 2, 2003 | 10:47 PM
TypeSDragon's Avatar
Loving my 08 TLS!
If you lowered with comptechs, you stock shocks should be fine for a while. I lowered my car a little over a year with CT springs and the ride is still great with the stock shocks.
Old Mar 7, 2003 | 12:37 AM
typesdragon any noises what so ever even the slightest or is it like stock no noise?
please i need to any noises what so ever?
also hows your camber? need one? tires balding inside?
ride?
Old Mar 11, 2003 | 11:50 PM
showoffnyc4's Avatar
im selling my comptech springs let me know if u want to buy them
Old Mar 12, 2003 | 08:47 AM
Mr Zipps's Avatar
I just PMed you.
Mr
03 ABP TL-S
Mr_@yahoo.com
Old Mar 12, 2003 | 10:10 AM
accordv6's Avatar
I lowered my car with Comptech springs the day I brought it home from the dealership with 9 miles on it.........and even though I'm sure the stock shocks would have lasted for a while, I opted to replace them with Illuminas. I just can't stand it when people ride around lowered on stock shocks.....just seems like the ghetto way to lower the car. If you want just "the look" than the stock shocks will be okay for a while (but they are gonna blow eventually), but if you want added performance and ride quality, aftermarket shocks are a must in my opinion.
Old Mar 12, 2003 | 07:35 PM
Edward'TLS's Avatar
6G TLX-S
Believe me, I have seen people who were so tight on their budgets but so eager to lower their cars that they actually have the stock springs cut. A turn or two is cut from the stock springs and bingo - dirt cheap lowering, but the car will bottom like crazy because the spring travel is all screwed up.
Old Mar 13, 2003 | 01:21 AM
chochox's Avatar
how much you sellin your comptech springs for?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
