spring question
Old Mar 18, 2008 | 10:34 AM
chrismeoli's Avatar
spring question
Ok, so I changed my front struts about 9 months ago, after a long hard 130,000miles. My question is this - what is the life span on springs? My car still feelis like crap after putting new struts on. Maybe the springs?
Old Mar 18, 2008 | 10:44 AM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
so, stock springs?
Old Mar 18, 2008 | 10:45 AM
chrismeoli's Avatar
yes still on stock springs
Old Mar 18, 2008 | 12:00 PM
01tl4tl's Avatar
fsttyms1 will say they last forever- others will say 100-150k and they have lived a good life.
What brand of shocks did you put on- that could be the real answer- not the springs!
Old Mar 18, 2008 | 05:59 PM
chrismeoli's Avatar
didnt have much $$$ so i only went with KYB GR2's , you think that is the issue or should i check out lower ball joints, just did the uppers like a month ago. Just want a nice ride, it takes the bumps very hard it seems like.
Old Mar 18, 2008 | 06:43 PM
fsttyms1's Avatar
What kind of symptoms are you having?
Old Mar 18, 2008 | 06:45 PM
chrismeoli's Avatar
mostly just seems like it is banging harshly over every bump it hits. No real noises or anything to speak of, just a hard ride on average roads.
Old Mar 18, 2008 | 07:44 PM
fsttyms1's Avatar
Has it changed or has it always been like this? The TL has a firm ride
Old Mar 18, 2008 | 07:56 PM
chrismeoli's Avatar
oh its worse than it was, thought the new shocks would have fixed it but still BANGS over every little bump and dances across the road
Old Mar 19, 2008 | 06:16 PM
ChucksCL-S's Avatar
Springs may rust alittle, but I've heard they never really wear out.
Old Mar 19, 2008 | 06:32 PM
01tl4tl's Avatar
check the ball joints and the bushing at the other end of the control arm
check the sway bar mounts and endlinks for damage or looseness
recheck all the bolts for the shocks
I always said- KYB = kills your back lol
Old Mar 19, 2008 | 06:34 PM
01tl4tl's Avatar
check your tire pressure too, if its dancing- too high?
how about the alignment, change the shocks= changes the whole attitude of the tire to the road. Could be way toe out and makes it wander
bounce test each corner of the car, give it a few pushes down and it should be firm and stop moving quickly when you stop pushing on it
Old Mar 19, 2008 | 07:09 PM
fsttyms1's Avatar
Mine rides great, but im looking forward to bilstein or konis
Old Mar 19, 2008 | 07:11 PM
fsttyms1's Avatar
If your getting those symptoms after new shocks, its time you look into ball joints, and endlinks. See if they have play
Old Mar 19, 2008 | 07:16 PM
01tl4tl's Avatar
note that fsttyms doesnt use seat heat in Wisconsin!!!!
Not my first choice of people to ask about ride comfort.
Now, the guy with a back problem, him I listen to
Old Mar 19, 2008 | 08:12 PM
fsttyms1's Avatar
Ive got a back problem, Heat makes it act up. My back never hurts sitting in the TL. If my 97 year old grandma didnt complain about the ride it cant be bad.
Old Mar 19, 2008 | 08:26 PM
Simba91102's Avatar
Old Guy
Assuming everything else remained the same, it seems logic would dictate that your problem is related to the new parts. I can't help but think that after 130K miles, any springs would be clapped out and new shocks would just exacerbate that. After that many miles, I'm sure your remaining ball joints and/or end links would benefit from replacement, but I'd be surprised to hear that either of those areas are causing your harsh ride problem. If finances allow, and you plan on keeping the car for a while, I'd suggest you replace all of the wear items in the suspension.
Old Mar 20, 2008 | 06:46 PM
chrismeoli's Avatar
thanks guys, have a good feeling it is the lower ball joints. Pushed down on the corners of the car manualy and it stops pretty right. its just when i hit the bumps it bangs over them. Now I just gotta find a shop to press in the new lowers if i bring them my knuckles. By the way I just did sway bar endlinks as well, so they are tight.
jmoney2001
Aug 12, 2019 06:23 PM
divac
Aug 29, 2018 10:13 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
CLsuperhero
Sep 23, 2015 12:53 PM
datadr
Sep 12, 2015 09:12 PM
