sport shift mode and tranny failure
Hi,
After driving a M3 for some time, I"ve become accustomed to sport shifting with teh SMG on the BMW. If I do a lot of S/S mode in teh TL, do you think it'll increase the tranny failure rate? Also, I currently have 65K miles on the car, do you think my tranny will fail even? I'm hoping it's one of the TL's with "good trannies"--if that even exists.
Originally Posted by Pure Adrenaline
What year?
It's luck of the draw. Sometimes you get a good one, sometimes you get bad ones repeatedly.
my first went after 50k miles, then the second at 59k miles... soo it all depends on your luck...i acutally did read on a thread before that using the S/S mode DOES increase the likelihood of the tranny failing due to YOU shifting rather than the car doing it itself... i duno thass wat i read i dont know how much of that is true
good luck with everything
2001 with 65K miles...so ya.thanks for all ur input...I think,...*if* mine failed...replace under warranty and get another Car altogether...cuz...why the fuck should i keep a car with a known problem?
I better have gotten a good one.
Originally Posted by fsttyms1
what you need to do is switch the wires around so that the Plus is minus and the Minus is Plus. (the way honda should have done it)
thats not true. it still shifts the same way wether the computer does it or you tell the computer to do it
Peace, Jeff
Originally Posted by mezzerTL-S
the only difference is that when using the S/S you can hold the tranny in gear longer and down shift at a higher RPM which does put stress on the tranny, now having said that I do it all the time and have only changed out one tranny at approx 157000kms (about 96000 miles) and have another 55000miles on the 2nd tranny and still going strong.
Peace, Jeff
Peace, Jeff
S/S Tranny failure
From what I understood using S/S and forcing the car to redline a lot in 2nd gear will cause transmission failure. However that was before the recall. If you go in to the dealer for the recall they are supposed to install a lubricant injector for your transmission which focuses primarily on that 2nd gear. However I'm not sure how well that lubricant injector will work if you're always racing people at stop lights
that isnt the cause of our failures. the oil jet kit was to help keep the 2nd gear shaft properly lubricated. VERY few have ever had the 2nd gear shaft failure. we all have teh 3rd gear clutch pack failure which the oil jet kit does nothing for
Puh-lease
Just on this forum alone, we've probably had hundreds upon hundreds of documented cases where the third gear failed. This is the cause of the majority of transmission failures in our cars, and yet Honda won't perform a recall.
The second gear recall was just a publicity stunt to fool the public into thinking that "the transmission problem" has been addressed. What the public doesn't know is that the recall deals with a totally different, unrelated and rare problem. So why did Honda do this? It's cheaper to install oil jet kits than to fix the third gear problem.
I like Honda and all, but this is a cheap move, and a slap in our faces. When my brother got a new car a couple of months ago, the TL was a strong contender among the choices, and we both knew that if he were to get the TL, he would get the 6-speed without a doubt. And now that's what he has. 2G, 3G, they are both great cars, especially for the money. It's unfortunate that it had to have such a weak link.
And now the 6-speed units are having problems with blown oil seals, and a mysterious chattering/clicking noise. Honda should just quit doing transmissions and outsource to General Motors. BMW used GM's automatic transmission in their last generation 5-series. Honda should do that, too, since it's evident that they don't know how to do transmissions depsite their excellence in engine-building.
i dont know why honda is having such a hard time with their trannies??? hell the manuals are still world renowned for being teh best and smoothest shifting on the market. every magazine compares the tranny their testing to the honda. Its not like they cant handle teh power, they have been making 4 banger trannies that can handle upwards of 400 hp with out modification
Why did we have to get stuck with the shitty one!?
Exactly. Most notably, the Integra transmission. I know guys who are pushing 300-400 fwhp on the stock transmissions and they are holding up exceptionally well.
Auto transmissions are a lot more complex than manual ones because of the additional mechanical parts, solenoids, and computer shift program, etc. Plus the fact that this is Honda's 1st crack at the 5-speed automatic box. But I must agree that manual transmissions can withstand a lot more torque and horsepower. The 6-speed manual in the final year release CL-S does hold up very well.
Originally Posted by calman
My 02 TLS has just turned 100,000 km and I had it in for some A/C work and the dealer installed the oil jet kit at the same time. I have never had a stitch of tranny problems until they installed the kit. On the way home from the dealership, it started slipping and finally went away altogether the next day. Up unitl that point, I always felt I was one of the lucky ones because I never had a stitch of trouble with the tranny. Makes me wonder what the heck they did ( or did not do) when they installed the kit.
it has nothing to do with the kit or how they installed it. its just pure coincidence. the tranny will be fine in the morning then all of asudden it will be bad after lunch. thats just the way they are
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
