Spark plugs
Old Aug 29, 2009 | 07:05 PM
mmendelzon's Avatar
Spark plugs
Hello there im pretty new driver got an 03 tl S with 94 k on it got a couple questions
how do i get to the back 3 spark plugs ? do i need to lift the car?
2. The tranny was redone about 20 000 ago and im just wondering if its normal to feel a little kick back when it shifts from 1st to s econd gear (its 5 speed auto)
thanks to whoever replys
Old Aug 29, 2009 | 07:43 PM
ChucksCL-S's Avatar
Do the rear plugs from above, you'll have to lay over the engine. It's not too bad. The Passenger side rear one is a little hard to do, just take your time. Not sure about the tranny.
Old Aug 29, 2009 | 08:11 PM
01tl4tl's Avatar
check the DIY section for more on plugs
Use NGK Iridium or NGK Platinum plugs, and a very small amount of plug anti sieze on the middle of the new plugs threads
A 3 and 6 inch extension work perfect to slide down into the plug recess and reach the plug-you need the smaller piece to get past angle limitations. put plug socket with short extension and lower in, add long extension then ratchet
Get a 1 foot length of vac hose to fit over the top of the new plug...use to lower it in place and start the threads by hand
Some remove the strut cross bar for better room- but the 2 part, 9 inch total length extension is the trick
Old Aug 29, 2009 | 08:37 PM
topper1296's Avatar
I just changed out my brakes today to Brembo blakes and EBC greenstuff pads, but now I need to change my plugs. My current one are 107k miles old. How tight do the plugs need to be? What is the torque spec for plugs?
Old Aug 29, 2009 | 09:58 PM
cobalt107's Avatar
torque spec for plugs are 18N-M or 13ft/lbs.
Old Aug 30, 2009 | 09:14 PM
totaledTL's Avatar
Extra deep spark plug socket works great, also self aligns plug so you're less likely to crossthread.
Old Aug 31, 2009 | 04:44 AM
01tl4tl's Avatar
yes always use a correct spark plug socket with a magnet or rubber piece inside, makes life easy
I use the vac hose method for new plug to lower in place and start a few threads of install--- so I know for sure they are in correctly before applying any torque from a tool
Old Aug 31, 2009 | 07:50 PM
topper1296's Avatar
What is the vac hose method? Anybody have a pic of that?
Old Aug 31, 2009 | 09:39 PM
mmendelzon's Avatar
whats the diy section?
Old Aug 31, 2009 | 10:13 PM
EnvyAce's Avatar
its the 3rd thread on the main page of 2nd gen tls... for future reference
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old Sep 1, 2009 | 10:24 AM
sb65's Avatar
I don't see anything about replacing plugs in the DIY section. Am I just missing it?
Old Sep 1, 2009 | 02:43 PM
shiznut123's Avatar
The DIY thread seems to be missing the spark plug replacement thread.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
