spark plug decision
Old Feb 13, 2010 | 12:14 PM
drogersbruh's Avatar
spark plug decision
which spark plug would be the best to get for and 2003 tl-s with some mods. cause im planing on doing a full maintenance, and would like to know thank you.
Old Feb 13, 2010 | 01:04 PM
fsttyms1's Avatar
The stock NGK plug
Old Feb 13, 2010 | 02:48 PM
GujuTL's Avatar
wow...u could have searched for this and gotten the answer much quicker lol
Old Feb 13, 2010 | 06:10 PM
01tl4tl's Avatar
NGK Iridium or Iridium IX (racer version) of the correct heat range for a type S stock is a good start
Then do plug checks to see if that heat is good with the fuel/air/exhaust mix
Plugs tell you right away if the engine is happy
May need a step colder for long high speed trips or hotter plug for other uses
Old Feb 15, 2010 | 08:01 AM
bruistopher's Avatar
as said above NGK Iridium IX is where its at. they are $7 a piece at autozone or local auto parts store, coming to a total of $42 for all six spark plugs.
i also made a do-it-yourself (DIY) to help anyone that wants to learn the ins and outs of changing the spark plugs on our cars.
here is the link: https://acurazine.com/forums/2g-tl-1999-2003-98/spark-plug-replace-change-diy-760163/
have fun and if you do them. the rear passenger side spark plug is hard to remove but a breeze to put the new one back in!
Old Feb 15, 2010 | 10:12 AM
bonknhead's Avatar
x3 on the NGK Iridium IX. Easy DIY too.
Old Feb 15, 2010 | 10:22 AM
@bonknhead
Was the first rear passenger side spark plug removal easy? XD
Sent via BlackBerry
Old Feb 15, 2010 | 10:45 AM
01tl4tl's Avatar
its easy if you use a 3 and 6 inch extension on the plug socket- lowering down sections
There is even a bump out on the firewall for your hand!
Old Feb 15, 2010 | 11:09 AM
bonknhead's Avatar
Originally Posted by xlost4
@bonknhead
Sent via BlackBerry
It was probably the toughest to get to, but still not too bad. It took me about 30-45 minutes for me to replace all six plugs 2 1/2 years ago at 80k.
Old Feb 15, 2010 | 03:21 PM
it took me an hour considering it was my first time trying it out.
and 01tl4tl i know the trick of using the 3" and 6" extension. you told me that and i replaced my spark plugs a few weeks ago
Old Feb 15, 2010 | 06:50 PM
01tl4tl's Avatar
good!
just passing the info out again when I see the question- for the ziners at large reading this
Old Feb 16, 2010 | 07:06 AM
totaledTL's Avatar
Long reach plug socket works even better, IMO.
Old Feb 16, 2010 | 09:13 AM
fsttyms1's Avatar
@bonknhead
Sent via BlackBerry
Its very easy, spark plug change on these cars is a 20 min job on the TL-P 25 min on the TL-S (its easiest to remove the 2 bolts that hold the IMRC on and move it out of the way which takes the additional 5 min). I could probably get the garage cleanup in that time as well.
Old Feb 21, 2010 | 11:53 PM
IceCube's Avatar
Very easy change, I bought the NGK Iridium IX plugs and noticed a huge difference after the change out.
Old Mar 6, 2010 | 06:04 AM
mobybasher's Avatar
ViLLAIN
im on this fast !!!
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
