Spare engine block....
Old Nov 8, 2001 | 08:23 PM
NSX4dr's Avatar
Original Member #81
Cool Spare engine block....
I stopped by the dealership today to pick up a few things....
1. J30 block that has low compression
2. J32 block involved in an auto accident
The J30 is in good condition but needs rebuilding.
The J32 block has damage to where the water pump bolts up to it. The motor is a 02' w/ 2500 miles on it. I'm checking right now to see if the crank, pistons and rods from this will work in the J30 block with minor honing to the cylinder walls......
If anyone needs a motor or knows if the only difference between the J32 and the J30 is the stroke let me know, I think the bore is the same but the rod length is different.........
Old Nov 9, 2001 | 02:22 PM
NSX4dr's Avatar
Original Member #81
Hello anyone know any specs of these engines.........
Old Nov 9, 2001 | 03:16 PM
1999TL's Avatar
curious, how much did you pay for this?
Old Nov 9, 2001 | 04:52 PM
NSX4dr's Avatar
Original Member #81
$0
Old Nov 9, 2001 | 06:59 PM
RAdams's Avatar
The J30 is 86.0 x 86.0 while the J32 is 89.0 x 86.0. Obviously, the pistons would be different then. I'm not sure about the rods -- they could be the same (or very similar) as they have the same stroke. Unless of course the piston pin is in a different place in each of the respective pistons, then their lengths might be different as well.
Not sure about any physical differences between the actual blocks themselves.
What's wrong with the J30 that it needs rebuilding... and how would I go about acquiring a motor like this for the same (or similar) price??
Old Nov 9, 2001 | 07:54 PM
NSX4dr's Avatar
Original Member #81
J30 rings are bad....
I'm going to bore out the J30 and put the J32 internals in it.
Now, as for acquiring something for the same $$, that's a secret......
Old Nov 12, 2001 | 08:16 AM
RAdams's Avatar
Old Nov 12, 2001 | 08:52 AM
NSX4dr's Avatar
Original Member #81
Originally posted by RAdams
I was just kidding.......:p
Someone called me and told me to come pick them up before the junk guys do.....
Old Nov 12, 2001 | 09:13 AM
RAdams's Avatar
Lucky guy! Have fun with the buildup.
Aug 15, 2019 12:58 PM
joflewbyu2
Oct 8, 2015 11:16 AM
PortlandRL
Sep 14, 2015 12:01 PM
EE4Life
Sep 11, 2015 10:13 PM
KillerG
Sep 4, 2015 02:02 PM
