Solution for Trunk rattling
Old Mar 24, 2002 | 08:06 PM
For all those who have the mysterious trunk rattling noise, I finally found the problem, it was the two rubber stoppers on the trunk lid, they were tightened all the way which gave a gap between the trunk lid and body. I found out that these two stoppers can actually be adjusted. You'll need to partially unscrew these stoppers so that gives less room between the trunk lid and the car body. This should fix it.
Old Mar 24, 2002 | 08:50 PM
SL1200MK4's Avatar
Thanks for the info... you got any pics of those rubber stoppers?
Old Mar 24, 2002 | 11:56 PM
vperkins2's Avatar
Thumbs up
Good job! Question: How were you able to pinpoint where your rattle was coming from? I need to learn how to isolate them so I can start getting rid of them!
Old Mar 25, 2002 | 12:32 AM
Black TL's Avatar
Are you talking about a rattle when you close you're trunk and are on some rough grinded road? Or are you talking about the rattle from the stock sub? I know that the sub vibrates EVERYTHING on the back panel where it sits. The brake light, cover, metal tensioners (i think) and the actual panel. I figure there is nothing I could do about that so i dont even care anymore because i cant really hear it too much from the front. The rear passengers could hear it loud and clear though.
Rosh
Old Mar 25, 2002 | 08:46 PM
vperkins2's Avatar
I'm talking about a rattle that sounds like it's coming from the rear deck, where the sub-woofer is located, I guess. I'll drive around for a while with the radio off and see if I still hear the "ticking" (metal-to-metal) sound.
V.
Old Mar 25, 2002 | 10:39 PM
Cl2TLS's Avatar
that **** iin the rear deck is pissing me off. i can't find it!! when your driving it sounds like a metal to metal ticking, if thats what your talking about!! need pics to fix!
Old Mar 26, 2002 | 01:27 PM
acuraracer's Avatar
Ex-Acura Die Hard Veteran
I found out my rattling is the 2 torsion bars that cross eachother are hitting each other. They are broke I guess and are loose, thats why in my case at least.
Dave
baelim
May 10, 2018 09:53 AM
LoneRonin
Sep 28, 2015 09:11 AM
jmaxima03
Sep 27, 2015 10:22 AM
AcuraKidd
Sep 25, 2015 11:18 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
