Solution for splash guard paint rubbing problem
Old Aug 5, 2002 | 01:21 PM
Kramer's Avatar
For those of you that want to install the factory splash guards but are afraid of them scratching the paint here is a trick I am going to try. Make a custom paint protector by purchasing bulk material from one of the clear bra companies. You can cut a piece that will cover the area where the splah guard touches the paint.
It can be had in bulk at http://www.xpel.com/bulk.html
Also, I sanded the edges of mine down a bit, they were very sharp.
Old Aug 5, 2002 | 01:34 PM
NSXNEXT's Avatar
Re: Solution for splash guard paint rubbing problem
That's the key. Think about it...if the splash guard can wear through paint, it's gonna easily wear through the Xpel.
Old Aug 5, 2002 | 02:47 PM
Mr Zipps's Avatar
I want to install splash guards and havent heard of them rubbing and taking off paint. Is that true? Does warrany cover that if it does?
Old Aug 5, 2002 | 03:51 PM
baggsTLS's Avatar
Mr. Self Destruct
Yes it's true, search the site for some of the pix. It is not pretty.
I don't think anyone has had much luck w/warranty repairs for this. The dealer may try to buff it out, but I don't think you'll get a whole lotta help on this one.
If you put them on, just be sure to sand down the sharp edges or trim them up a little.
Old Aug 5, 2002 | 04:41 PM
I got mine off, and the dealer repainted the damages under warranty. I also got the OEM kit installed at the same time. Now i searching for mud guards that will fit with the OEM kit for the winter.
Anyone with a solution?
thanks
Old Aug 5, 2002 | 08:13 PM
Kramer's Avatar
Re: Re: Solution for splash guard paint rubbing problem
Our paint is paper thin as I'm sure you know. The xpel stuff is much thicker and more durable, especially if you use the type that is for headlights, it is about as thick as a quarter.
Anyway, it's definitely worth a shot.
le^2
Feb 18, 2021 10:44 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
nanos
Nov 12, 2015 08:41 PM
d.lim
Sep 15, 2015 08:54 PM
EE4Life
Sep 11, 2015 10:13 PM
