Snow and HID Lights..no meltin' happenin'
Ackniculous One
Ok, for you folks who drive during snow storms for long periods of time, do you ever have your HID headlight output diminished because snow builds up on the headlamps as you drive? This happens to me all the time. I know it's because the headlights do not put out anywhere near the amount of heat that halogens do. I know this never happend in my non HID cars because the lights heat up the lexan/glass, therefore melting the snow.
I'm thinking about rain-x'ing my headlight housing to make them more slick to ice and snow, but not sure if that would affect the lexan housing, i.e. discoloring it, etc? Anyone else have this issue? No issue for the fogs because they are glass and halogen and they are completely free of snow, but the rest of the car looks like I hit a snow bank!!
Registered Abuser of VTEC
Try the rain-x on a test area near the side. A very small area should be tested. If it doesn't have any effect, which it shouldn't, you should be okay. I have no reason to believe that it would etch the surface since it's a nonpolar molecule (if it was polar water would bond to it and it wouldn't do its job, but it bonds to the glass and headlights because the plastic and glass are nonpolar, at least i think glass is nonpolar).
Flyin' and Drivin'
I have put rain-x on my lights, windows, and mirrors.... it works great, and there were no "side-effects" on the lights. I do it about once a month.
Kollage is funn!
1 Post
yeah i've put rain-x on my headlights....doesn't do anything...WAX does though. i also know for a fact that rain-x works on the STOCK fog light lens. i car wax all my headlight, and tail light assemblies and it works great.
Drive fast & swerve
i use rain-x on my headlights and fog lights in between waxing and haven't had any problems with etching. if you use wax, i suggest a liquid wax since it's typically less abrasive. as for keeping snow from building up, i don't know that I've noticed a big difference, but it makes the lights sparkle when it's clean and that's really what i like about it.
Mile High
Actually I was traveling thru Monarch Pass when it was blizzarding heavily the weekend before thanksgiving, and i stopped at the crest of the pass to take a few pics, and there was ice everywhere but my headlights, it was cool to see the ice surrounding them. its wierd that we have had opposite experiences, wish i knew how to post pics
no problem with mine (unless like left over night, then i have to usually scrape them off if it snowed)
My trick is to live in FL. Works pretty well. lol...
I havent used anthing for my lights for fear of chemical interactions. Rain X says to stay away from plastic lenses, etc. It can soften them, but it depends on the plastic, so Rain X covers all the bases and says no plastic.
I need to polish my healights though. They are so pitted.
Good luck!!
Good luck!!
2003 SSM TLS
What is snow? Is that the white stuff that I see in pictures from up north.
We just don't have that down here, and when we do I don't trust the other drivers enough to risk the TL and keep it inside.
I use wax on my headlights. It will help the snow & slush "slide" off of the light instead of freezing on it.
Ackniculous One
Originally Posted by Crazy88
