smoothest lowering springs
hey i will be soon getting an OEM body kit for my 00 tl and would like to get rid of most of the wheel gap. I dont want too much of a bumpy ride... so which springs should i go with? also, how much is installation?
And what was that phone number to get the OEM body kit? something liek ray laks acura...
thanks,
mike
thanks,
mike
If you change your springs make sure you replace your shocks as well, get a camber kit too. I would probably just go for a coilover kit that comes with everything and whole new pillowmounts.
Comptech is a very nice ride. Its a bit bumpy but you get used to it. Handling is 10 times better.
Boomer SOONER
you dont have to get new shocks or a camber kit with most shocks. If you lower it more than 1.75 inches then a rear camber kit may help, but even if you do - a camber kit isnt a must. Your tires may wear a little off thats all.
obviously new springs will shorten your shocks life, but wont hurt anything, especially if you dont have lots of money to drop at one time
Purchased: April 28, 2001
Originally Posted by Edr0e
If you change your springs make sure you...
get a camber kit too...
FYI when I got my Comptech springs installed I naturally got an alignment. I don't have a scanner with me, but the sheet shows that all 4 wheels were still within spec.
Perhpas you'll need it if you get the H&R sports...but with Comptech's, I can verify that a camber kit is not needed (full tank of gas...no system in trunk).
Look for lowering springs with the same or similar dampning rate as the stock shocks. That would mean find out the stock dampning rate and compare to the aftermarket.
h&r makes the best springs, hands down
Boomer SOONER
Originally Posted by MistaWongy
i will have a system in my trunk
2 kicker S12L7's ... i dont feel like buying a camber kit, so which springs u think i should go with?
Comptechs by far, because the rear springs keep the back slightly higher than the front, so with a system, everything is very even. Ive seen cars with HR's and systems and the back sags..ghetto if you ask me.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
