slight engine detonation
Old Oct 8, 2004 | 09:51 AM
strannik18's Avatar
Guys....
I need your opinion.
I get slight engine knock on my 2000 TL. Odometer reading is at 116000. I've had all services done and change oil religiously. Gasoline used is at least 91.
I can hear detonation at certain speeds when transmission is in the higher gear and I rapidly press accelerator pedal. It is not that loud but still pissing me off - I want my Acura to run smooth
There is no check engine light - proof for the sensors to be fine. I guess I cannot claim my extended warranty with Acura - they need to see the light first to run diagnostics.
Anyone knows what it might be? Is it a valve clearance need to be looked at? ...Damn...only 116000 km.
Any responces are appreciated.
Old Oct 8, 2004 | 10:28 AM
bigman's Avatar
'Big Daddy Diggler'
have you checked the spark plugs?
Old Oct 8, 2004 | 10:30 AM
Chemmech's Avatar
Get some fuel injector cleaner like Techron.
Old Oct 8, 2004 | 10:32 AM
strannik18's Avatar
I put in brand new Bosch 4+ just a couple of months ago
Old Oct 8, 2004 | 10:33 AM
strannik18's Avatar
Do you think injectors are plugged?
Old Oct 8, 2004 | 03:02 PM
fsttyms1's Avatar
those arent any good for our cars!!! get the NGK iridiums. 2nd are you sure its detonation? get a fuel treatment(fuel injector cleaner) run that thru acouple tanks. but first get rid of those plugs
Old Oct 8, 2004 | 04:41 PM
etxxz's Avatar
@ slide or die @
Tru theres this Injector/fuel sys treatment at EvERY pump station that you add to every tank...do it 1nce every 6months.
Like FSTTYS1 said, those sparks you put are a no no, get NKG iridiums and Oh...THE MANUAL SAYS 93OCTANE UNLEADED...91 sometimes is acceptable...but "atleast 91" is not acceptable.
Old Oct 8, 2004 | 05:48 PM
1fasttl's Avatar
those plugs are shit. They might be running to hot. Like everybody is saying, go back to using the ngk's and drop in some injectors/fuel treatment.
Old Oct 9, 2004 | 10:26 AM
strannik18's Avatar
Thanks guys...I'll try to switch the plugs. Funny...the reason I got them in the first place is because I read some good responces from this board....go figure
rockyboy
Aug 4, 2024 10:35 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Frathora
Sep 28, 2015 11:29 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
Mike Bertram
Sep 10, 2015 09:27 AM
