Sirius or XM Radio Installs - Let's See Them
Old Mar 16, 2007 | 05:42 PM
1osunut's Avatar
I started this thread to see where others are installing their Sirius or XM radios. I installed mine in the sunglass holder. I used a Kenwood Sirius reciver (because iy fit nicely) that plays directly through my radio on 88.3. The sunglass holder was trimmed clean and can still be locked into the close position for a totally stealth install. The brains of the unit are mounted in the trunk on the underside of the rear shelf (completly out of view). I could not stand the small black antenna box on my trunk, it drove me crazy. I bought a XM roof antenna from a 2006 Accord EX 4dr and converted it. I removed the guts and used a grinder to clear out a flat surface for the Sirius antenna. I then lowered the headliner and found the center of the roof. I drilled a hole the exact size of the one in the Accord roof and installed it using the same hardware. Once I made sure the reception was good I had the housing painted WDP. The install gets compliments everywhere I go and there is not a wire showing anywhere. I would really like to see the other unique places people have installed their Sirius and XM units. I always seem to get great ideas on threads like this.
[IMG][/IMG]
[IMG][/IMG]
Old Mar 16, 2007 | 05:54 PM
thcmagik's Avatar
nice i like that idea, but im just not a fan of the satellite radio, cds work for me
Old Mar 16, 2007 | 06:05 PM
MikePA's Avatar
Old Mar 17, 2007 | 12:40 AM
Hockeyman's Avatar
slobalt defender
wires are all tucked in now so it looks a lot cleaner, just no recent pics. Cig lighter wire is now running to the center console plug. CD's still come out and load perfectly, and it is not really crooked, it's just the angle of the camera.
Old Mar 17, 2007 | 08:28 PM
ronie's Avatar
DAS and EFX,
I biggity burn riggity rubber when I blabber great
I miggity make the Wonder Twins deactivate!
We're around the same age..
I Grew up in the Bronx. 183rd And Beaumont Ave.
Old Mar 17, 2007 | 08:42 PM
1osunut's Avatar
Age is only a number. I listen to everything.
Old Mar 17, 2007 | 09:50 PM
RidinDurty's Avatar
The setup you guys have is very nice, but the head unit i have at the moment is XM ready. Basically i will only have to install the antenna right? I would like to use the same one you have 1osunut
Old Mar 17, 2007 | 10:17 PM
orgnlprankster7's Avatar
08 Civic SI
i ran all the wires behind the dash. it looks pretty clean and is in reach. altho i hate my antenna i wish i had the balls to drill a hole in my roof
Old Mar 18, 2007 | 08:31 AM
1osunut's Avatar
If you use all the mounting hardware that the Accord uses its no problem. I did not even need to use silicone or anything to seal it. The antenna has a rubber gasket bottom and it form a tight seal. This car has been driven in the rain and is washed 3 or 4 times a week and not one drop has leaked into the car. You just have to drop the rear of the headliner first so that you drill the hole in a spot where you clear any moonroof wires or bracing.
Old Mar 18, 2007 | 11:36 AM
azninvazion's Avatar
Ur Mutha She Stinks!!
Originally Posted by 1osunut
[IMG][/IMG]
where did you get the receiver from? and What are the dimensions of the receiver? I've been looking for something like that and i can't find a thing.
Old Mar 18, 2007 | 04:12 PM
xyrcncp's Avatar
Not necessarily. If your headunit has an XM TUNER built-in then yes, all you would need is an antenna and a subscription of course. Otherwise, you'll need an external tuner. For example, my Alpine head unit is SAT ready (XM or Sirius), all I have to do is add the appropriate tuner and antenna to it.
Old Mar 18, 2007 | 04:19 PM
RidinDurty's Avatar
hmm I also have an Alpine head unit but it only says XM ready. I guess I also have to purchase the tuner. How much is XM per month? and how much would the tuner and accord antenna cost me? Thanx guys.
Old Mar 18, 2007 | 04:56 PM
xyrcncp's Avatar
As far as I know even if it says XM ready, it will also work with Sirius, but don't quote me on it as my HU says SAT ready.
XM I believe is $12.95 month, the tuner is $95 from crutchfield ( http://www.crutchfield.com/S-hPnFaol...0&I=700XMALPIN ) and it comes with the antenna.
Old Mar 18, 2007 | 06:22 PM
1osunut's Avatar
The unit I have is a Kenwood. I have seen them on ebay. I will look at the car in the AM to get the model number off it for you.
Old Mar 18, 2007 | 07:36 PM
xyrcncp's Avatar
Crap, forgot about the accord antenna, I found this one:
http://www.hondaautomotiveparts.com/...NTENNA-SPEAKER
Part #16 $31.21
Old Mar 18, 2007 | 07:39 PM
RidinDurty's Avatar
Part #16 $31.21
haha thanx man. I appreciate all the help.
Old Mar 18, 2007 | 09:15 PM
NSXNEXT's Avatar
Old Mar 18, 2007 | 09:19 PM
xyrcncp's Avatar
No problem. I started looking for it as soon as I saw 1osunut's pictures.
Old Mar 18, 2007 | 09:26 PM
RidinDurty's Avatar
One more question. The link you posted, does it bring all the wires i need to connect it to the radio?
Old Mar 18, 2007 | 09:32 PM
xyrcncp's Avatar
I would think so. When I had my old car and had the Sirius tuner installed, it came with like a 15ft. cable to connect to the HU.
Old Mar 18, 2007 | 10:00 PM
Another questions are all you guys using the FM transmitter or are you actually using an aux cable to hook it up?
Old Mar 19, 2007 | 02:23 PM
1osunut's Avatar
The model number on my Kenwood unit is KCA-R70FM. The unit works incredible.
BoricuaTL
Apr 8, 2016 01:08 PM
koju01
ILX Audio, Bluetooth, Electronics & Navigation
Dec 14, 2015 02:17 PM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
