Silver Bottom CDRs?
Old Apr 5, 2005 | 06:35 PM
chaitanyaacura's Avatar
Silver Bottom CDRs?
Hi,
In my continuing research to find out which cdr would work.. I wanted to try out the Silver Bottom (recording surface -silver) for the final.
This is because , I observed that all the original CDs have a pure silver bottom as opposed to blue/gree/gold//etc..
Can anyone tell me where can I buy a CDR with a Silber bottom(recording) surface.
PS. I have tried the black bottom memorex ..works fine until I try to skip to another track.
Old Apr 5, 2005 | 06:40 PM
You can't. Those CD's aren't burned in the same way as a CD-R. They are pressed like a license plate.
Mods: Post should be closed. Doesn't belong on this board.
Old Apr 5, 2005 | 07:22 PM
fsttyms1's Avatar
it doesnt matter what color, its the manufacturing process of the blank media and who makes them. (the same place doesnt make them for the same place every time/batch) you either get lucky or you dont when you purchase a spindle of them. it just comes down to the HU not likeing to read CD-R's
Old Apr 5, 2005 | 10:13 PM
aaronnn's Avatar
instead of buying a bunch of different cd-r's and wasting all that time and money you could just go on Ebay and buy a 02-03 6-cdchanger for 150. then you can just replace your whole HU easily, since its all straight forward plug and play. its easy as that.
Old Apr 8, 2005 | 10:37 AM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Originally Posted by chaitanyaacura
Hi,
The closest thing you can get is this or the ones from here
But to be honest, these aren't "pure" silver/silver. Its a really really small amount of dye. In addition, what ends up happening is the silver on top is the actual reflective surface that is used to read the bottom of the disc so if you scratch the top (which is extremely easy), your cd is unusable. I would not buy these ... again
I've always had great results with Memorex, Maxell, and Imation (OG ) media. Also as a side, if you decide to put a cd-r label on it, it will get stuck (well this is true for the 6-disc indash units )
Good luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Desert Ridge
Sep 27, 2015 02:37 PM
