signal lights led's ?
ecaf005 (01-04-2013)
Clean ride.
mugenspire (12-28-2012)
Did you guys get yours at dt-autotech on ebay?
I've been wanting to do this but never gotten to it. It seems like the LED bulbs comes with the resistors too correct? And all that's needed to do is to wire up the resistors.
3 pedals in my 99 TL
Yea I just left it hanging. Not too many places to bolt it to in the area around the headlights. Plus their small so not much room to stretch either. Although I'm sure you could find a spot to bolt or zip tie it to I was just lazy to look lol. And yea you're right feijai all you need to do is wire up the resistors. Bulb is plug n play its really easy takes like 10 mins with the front bumper off. I got mine from a member/homie on here 'kidduce'. He helped me with instructions which made it 10x easier. And it looks sick as fuck haha. Pics don't do it justice but you get the idea I'm sure. Hope this helps.
@Mikeshlong On IG
Forget the resistor, there is no reason to cut into the wires imo . The turn signal flasher is what I'm assuming a relay that makes your turn signal blink . You swap out the OEM honda one and put in one from autozone its labeled TE34 i believe. Its located on the drivers side uder the steering wheel to the left, but not the fuse box. I can take some pics and post for you guys if you want. I bought resistors and everything but than found this out and was like well that's easy enough .
^ you don't have to cut any wires so idk what you're talking about lol. All you do is clamp the resistor onto the current wires like I explained earlier which are the green and black and you're good. No cutting necessary. No need to make it complicated.
so mikebikelife all your saying is there a aftermarket relay they make and also i would like to see the pics plz thanks guys i still haveint got my lights yet i have purple lights and i dont rely like the amber that much i think the white would look better
@Mikeshlong On IG
This is what you need .
http://www.flickr.com/photos/mikebikelife/8333461411/http://www.flickr.com/photos/mikebikelife/8333461411/ by http://www.flickr.com/people/mikebikelife/, on Flickr
It goes up here .
far right of the picture .
http://www.flickr.com/photos/mikebikelife/8334519770/http://www.flickr.com/photos/mikebikelife/8334519770/ by http://www.flickr.com/people/mikebikelife/, on Flickr
It goes up here .
The following 3 users liked this post by mikebikelife:
Where did u find it at (the fuse thing)? I need 1, I have LEDs in the rear and just ordered a set of switchbacks...not good with all the wiring n stuff YET lol
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
