Side Motor Mount Tips
I ordered a side motor mount offline and plan on installing it this week/weekend. From what I have read in searches, it seems that I have to support the engine from below with a jack, then remove the motor mount and install the new one. It seems a bit easier said than done. Is there anything I should keep in mind when doing it or is there a particular place to support the engine from? I couldn't find a DIY so any help at all would be appreciated. Thanks.
If your replacing the passenger side motor mount nothing has to be done)dont have to support engine). All you have to do is unbolt it and replace it. I would recomend unbolting the 1 single bolt that conects the motor to the mount first, then remove the 2 bolts that attach the other piece to the motor. After that then remove the 3 bolts that hold the mount it self and wiggle it out. then replace in reverse order
Originally Posted by bkzjimmy
if ur doing it, whip out the camera and make a DIY . I had mine changed not too long ago, but my mechanic did it.
Originally Posted by fsttyms1
for the side ???? You should be able to see how to do that one by looking at it. a few bolts then remove easy as that
bkzjimmy, If I have time I'll make a quick DIY and post it.
i know but some people are handycap when it comes to doing things, me...im just lazy, i dont have the right tools either. and plus he said in the first post he was looking for a DIY so i figured he can just make his own
Thanks for the helpful tips! I'll give it a shot and let you guys know how I make out.
Did mine, and it wasn't too bad. You will have to unbolt the ABS from the body and lift it up a bit (Be careful not to bend the lines) to wiggle the side mount out.
Trancemission helped me do the side and front. He can give you some help along with Kris.
That's actually the cruise control unit and you should remove the two screws holding it and the bracket in and move it out of the way.
I thought it was a PITA to get out with all the items removed, fsttyms is a car/TL god , so we of mortal status found it educational, but tough.
as for the mount, ive had mine in and out so many times its a cake walk. if you play with it while trying to get it in and out you will see that there is a specific angle that it will just slide right in and out (not something that is easy to describe, once unbolted you will see it)
sockr1
10-01-2015 01:31 AM
