shifting TLS
Re: shifting TLS
Originally posted by bliscio
how do you guy's think you get more outa the tls slap stick....
do you let it almost redline, or keep the pedal down when shifting and what are the speed gaps each gear should be in?
The speed listings for each gear is in the owner's manual.
When you want to run hard, obviously it's better to take each gear to redline. You should actually shift a tick before redline b/c there is a .5 second delay between you shifting, and the actual shift occuring. If you wait too long you'll hit the fuel cutoff. As for the pedal thing... the car is an automatic, even if you're using SS, so there's never a need to lift off the gas unless you're braking.....
Re: Re: shifting TLS
Originally posted by juniorbean
man.. you never even opened your manual, did you?
Go out today, go about 30. You'd probably be sitting in 4th, do a double downshift while punching it. You will see the difference.
Go out today, go about 30. You'd probably be sitting in 4th, do a double downshift while punching it. You will feel the difference.
SidhuSaaB
05-30-2020 01:40 AM
Hines57
09-24-2015 02:58 PM
