shave trunk
thats the method- use a heat gun, hair dryer or park the tail into the sun a few hours and they come right off
Its just double sided foam tape holding them on
Keep in mind that after taking the letters off and cleaning off the glue residue, you still might be able to see where the letters were. I could on my dark green pearl. No amount of polishing would get rid of the ghost image so I ended up putting the letter back on. I was glad I only removed the first 'A'. I did not have this problem where the 3.2 TL letters were.
'13 Hyundai Sonata
^to add to that. If you have a buffer then you will be able to get rid of the image. I also read on here that if you take a terry cloth, some rubbing alcohol, and some elbow grease it will go away.
I tried everything after I took the 'A' off. Nothing got rid of the ghost. I eventually rubbed through the clear coat. Fortunately, it was under the 'A' so when I put it back on, it was hidden.
justin.w13.walker
09-22-2015 02:21 PM
