Services
Services
My car has a 6 yr extended warranty. Is it true that u have to start paying the services after 2 services. In addition, if u want to replace the wiper blades, u are charged for it? If that is so, what EXCATLY does the warranty cover? Just the tranny replacement?
Your 03 is covered by the 4yr/50K warranty - and if you bought the car used from a dealer, then there's a chance it's certified too. If you're still under 50K, then all warranty work is free so long as it's done at a dealer and the part that fails is not do to a mod. The warranty covers everything that is not considered "expendable". Wiper blades, according to my dealer, are considered "expendable", and are not covered. Other expendables are things like the battery, fluids, tires, and in some cases brake pads (it depends on whether they wear due to the rotor issue or not). If you call Acura's main number, you can request a booklet that will have all the warranty details – that should cover all the particulars.
Back from the dealer.. I just checked my invoice.. For the odometer IN/OUT box, it says in is 16800 and out is 16896!! WTF, they drove my car for 96km in 2.5 hr?
