service manual
Old Jan 18, 2011 | 03:00 AM
soria's Avatar
service manual
My entire service manual doesn't say anything about the front or rear sway bars. I was looking for torque specs and basic install instructions.
I thought the service manual had everything? Maybe I missed it...
Old Jan 18, 2011 | 04:08 AM
01tl4tl's Avatar
whats not there is in our DIY section
are you replacing the bars with larger or just need end links or center bushings?
most intructions come with torque specs and new bolts
You can test any nut/bolt before removal and determine its current torque.
Set the tool to tighten and lower value than you think its at- keep turning up tool until it tries to move bolt- thats your current setting!
Old Jan 18, 2011 | 06:34 AM
totaledTL's Avatar
Originally Posted by 01tl4tl
...You can test any nut/bolt before removal and determine its current torque.
That wouldn't be very accurate to use to retighten would it? If corroded, rusty, overtorqued, etc. a false value would be read-
Old Jan 18, 2011 | 11:13 AM
01tl4tl's Avatar
I meant clean -not rusted bolts---that have not been removed before
you can self calibrate/test a torque wrench or find the current value of a bolt
you can also go by the guide on bolt diamter and torque value
there is one for every size and bolt grade
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
dirleton
Sep 25, 2015 12:25 AM
