Sensor at Center Base of Windshield
Old 10-31-2014, 11:23 AM
MikeekiM's Avatar
What is the sensor at the base of the windshield, right dead center?
Old 10-31-2014, 11:27 AM
Be a better driver
RedRyder's Avatar
For auto climate control, auto headlights, etc depending on how your car is equipped.
Old 10-31-2014, 11:56 AM
MikeekiM's Avatar
Is it a light sensor, or a temp sensor?
I guess if it is used for auto headlights (which my car did not come with), then it must be a light sensor, eh?
But wait... If it is for climate control, then it must be temperature based, right? It is possible for it to be sunny, but cold...
How do I prove to myself whether it is working properly? Can I cover it from light and validate some resulting behavior?
Old 11-01-2014, 11:32 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
try reading your owner manual
don't have one? here is the free download Acura Owners Site | Exclusive Knowledge, Service, & Benefits
the top of dash sensor is for temp and it works with its mate below steering wheel/dash on drivers right knee area
all part of the fancy auto climate control unit
reminder to all: should replace the cabin air filters once a year! have you ever done yours?
Old 11-01-2014, 12:09 PM
MikeekiM's Avatar
Will do... Thanks...
Old 11-02-2014, 09:57 AM
Ndanny's Avatar
Mines fell through the hole... How would I get it out?
Old 11-02-2014, 10:14 AM
bk85's Avatar
Ditto^
Old 11-02-2014, 09:17 PM
Dabu's Avatar
Mine also seems to have fallen through the hole
Old 11-02-2014, 09:35 PM
MikeekiM's Avatar
What do you guys mean? Are you saying that you took the cover off, and the sensor has fallen through? Or is the cover missing?
I am just a little shocked that all of you bothered to take the cover off to examine it... Unless I am not picturing this right...
Old 11-02-2014, 09:40 PM
Dabu's Avatar
I noticed the other day there was a hole where this "sensor" is supposed to be, base of the windshield in the center.
Old 11-02-2014, 09:53 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
The Top Sensor in the Dash is for SUNLIGHT! Basically when you have the sun aiming at it the "AUTO" feature of the A/C will re-direct the air through the main front vents (In Full AUTO the air comes from every single vent under normal use). If yours fell then the vents will not auto-switch to the fronts when the sunlight is straight at you.
The A/C Temp sensor is located at the steering wheel, Just left of the A/C Controls.
Old 11-03-2014, 07:21 AM
Ndanny's Avatar
Any tips on how we would pull this out and back into its place? It's just sitting down there leaving a weird hole.
Old 11-03-2014, 08:24 AM
Skirmich's Avatar
Sadly there is not enough room there for a quick fix.
It looks like dash removal PITA time.
Ndanny (11-05-2014)
Old 11-03-2014, 08:42 AM
Dabu's Avatar
Doesn't sound super necessary to fix right now, I'll wait until I have to remove the dash for something else and do it at the same time.
oyayjoe
01-01-2019 10:17 PM
james357
02-13-2016 02:37 PM
Oakes
Wash & Wax
11-12-2015 09:34 PM
09-17-2015 09:01 PM
Quick Reply: Sensor at Center Base of Windshield
