Seafoam problem...
just pull out the #13 fuse on the passenger side panel. It's the ECU and Clock fuse. Resets the ECU without disconnecting your radio so you don't have to go through the hassle of the radio code.
DONT reset the ecu for this one- no need to make the computer relearn everything
Most of the time its failure to get the engine and cat hot enough on the blow out drive.
4000 rpm in 2nd gear for 10 minutes will take care of the problem
What happens is loosened goo gets stuck on the O2 sensor- it burns off with a days driving.
Those who follow the DIY with precision have no problems- but its a minor thing for the CEL, and does indicate the need for retreatment in a month or 2.
Use Deep Creep seafoam in spray can to do vac port- beats the hose and can method big time
Its fine to reset the ECU when the car has had major mods to it, or the battery was off for some reason
When you have a problem like this - with crud temporarily blocking the O2 after seafoam - if you reset the ecu now- BEFORE fixing the problem, it is learning while the problem is still self correcting
Thats giving bad info to the computer
Fix the problem first- then reset the system- thats what I meant
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
