Sc Owners .. Help
Old May 7, 2005 | 10:50 PM
Hurleysurf24's Avatar
Sc Owners .. Help
OK i got the sc base in and i set it into the bracket ... i trimmed the fan housing and then placed it in.
Anyways i not iced that the freaking fins on the fan are hitting the base of the sc !!! WTF MAN ?
Would it be that big of a problem to trim about 5cm off of the corner of each blade so that it clears correctly? Or will this cause some sort of problem ?
Old May 8, 2005 | 04:09 AM
MikePA's Avatar
Do the instructions indicate you're supposed to trim the fan blades? If not, I'd be concerened the SC is not correctly placed.
Old May 8, 2005 | 04:27 AM
REDLINEN's Avatar
Missing my Acura's
Ya would get more helpp in the cl forums im sure!!!!!
Old May 8, 2005 | 12:31 PM
yes it is placed correctly .. everything lines up including the brackets ..
Old May 9, 2005 | 04:29 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
trimming the fan blades yourself will most likely cause an imbalance in the impeller which will result in high vibration and eventually the fan will eat itself. i hate to say it but this would need to be professionally done to ensure nothing goes wrong.
of course you could just try it and if you're really careful then who knows, you might pull it off.
i would check in on the cl forum and see what everyone else had to do. let us know if you find anything that could be useful.
good luck!
SSTS
Old May 9, 2005 | 07:10 PM
fsttyms1's Avatar
if the instructions dont call for triming the fan blades dont do it. it means its not positioned properly.
Old May 10, 2005 | 04:00 AM
MikePA's Avatar
That's the question I asked...
I read the instructions and there's no mention of the trimming the fan.
Have you replaced the fan shroud with the one in the kit?
Old May 10, 2005 | 01:30 PM
hey i just recessed the motor more . .everything fits properly now
Old May 10, 2005 | 05:20 PM
99TLKID's Avatar
L33t Sk8er
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
Jimmy_D
Oct 7, 2015 11:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
