Sanding headlights question
Old 04-06-2010 | 11:13 PM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
Question Sanding headlights question
Hey guys I've baked my headlights and gotten them apart and sanded with 100 grit paper but the corners are so hard to sand just wondering if there's a technique that works best for sanding the corner lens
or could I possibly use some paint stripper to get the chrome off
I'm having trouble with the lil lines on the corner
Old 04-06-2010 | 11:24 PM
snowman81's Avatar
Sippy Cup (x2)
No special technique when I did it, just gotta fold the sandpaper and be careful. And I'm guessing you meant 1000 grit and not 100 grit, right?
Old 04-07-2010 | 12:15 AM
hANDYcaptd's Avatar
It's the Halladay season!
^ That's what I was thinking...100 is definitely not enough...
I'd actually go up to 2000 grit before buffing.
Old 04-07-2010 | 12:19 AM
kdawg8526's Avatar
i used 100 grit to get rid of the chrome to start then i was thinking id move upto 250 grit then 1000 grit
Old 04-07-2010 | 01:18 AM
xtremex626's Avatar
Regional Coordinator (SoCal)
i used 100, then 240, then 1000.
100 should strip out whatever chrome you see. try scrubbing harder, it should take it off. i just finished blacking out my headlight housings. if you can't get the sandpaper into tight places , hold the sandpaper with a tweezer. that's what i did.
but don't stress too much, the paint will still stick even with some chrome on the corners.
Old 04-07-2010 | 01:20 AM
kdawg8526's Avatar
so i dont have to get every lil millimeter of chrome off? ill post a pic to show how it looks
Old 04-07-2010 | 01:38 AM
kdawg8526's Avatar
this is how it looks the rest of it is sanded perfectly its only the corners that are pissing me off.. im really impatient can i just paint it now or will it get messed up? and those lines dont go away
Old 04-07-2010 | 02:14 AM
xtremex626's Avatar
naw man.. you dont need EVERY milimeter of chrome off .. in fact .. most corners i barely even got (the hard to reach spots) ... as long as you primered , you're fine . give yourself a break .
100 > 250 > 1000
2 coats of primer , wait 45 mins after each coat , wetsanding after each coat
then black paint .. 3 coats
then clearcoat .. 3 coats
you'll be fine
Old 04-07-2010 | 02:16 AM
xtremex626's Avatar
here's how mine turned out
Old 04-07-2010 | 02:24 AM
kdawg8526's Avatar
yours looks awesome.. stupid question here how do you wet sand?? lol
Old 04-07-2010 | 02:35 AM
xtremex626's Avatar
basically dip the sandpaper into water and sand . just make sure the surface you are sanding is constantly wet . it's really not a big deal haha . sometimes i'll just dry sand if im lazy .
wetsanding is just to remove the small little imperfections like bumps and drizzles
Old 04-07-2010 | 02:38 AM
kdawg8526's Avatar
^oh oh haha no wonder its called "wet sanding" stupid me lol
Old 04-07-2010 | 02:39 AM
xtremex626's Avatar
LOL
Old 04-07-2010 | 08:44 AM
'03TL-S's Avatar
Like stated above, you don't need to get all of the chrome off. And learn how to be patient
Old 04-07-2010 | 08:18 PM
ANC297's Avatar
Bonki' Ehrite!
I have a diy in the diy sticky for blacking out lights. Check it out!
Old 04-07-2010 | 08:42 PM
kdawg8526's Avatar
i seen your diy thats what i based it off
Old 04-07-2010 | 08:59 PM
assclown's Avatar
2000 acura tl FPR
SNOW!!! your still alive???? i haven't seen you forever
http://www.youtube.com/watch?v=BETIgHjMrpw
Old 04-07-2010 | 09:06 PM
ANC297's Avatar
Bonki' Ehrite!
Patience is the key for this project. I didnt black out my corner lights, but the crevice that goes around the high beams was hard for me to sand, and all of the chrome didnt come out of there....As stated above, all of it doesnt have to come off, but get off as much as you can.
Good luck.
Let me know if you have any more questions.
Old 04-07-2010 | 09:23 PM
kdawg8526's Avatar
thanks i got one sanded down as much as i could gonna paint it and see what happens how many coats of primer paint and clear coat is needed?
Old 04-07-2010 | 09:38 PM
hANDYcaptd's Avatar
Wow, uber fail. I thought you meant sanding the outside of the headlights....I read too fast
Old 04-07-2010 | 09:39 PM
kdawg8526's Avatar
haha no wonder i was like watt is he talking about
Old 04-07-2010 | 09:44 PM
xtremex626's Avatar
100 > 250 > 1000
you'll be fine
this
Old 04-07-2010 | 09:48 PM
kdawg8526's Avatar
sounds good imma do that right now how long should i wait between paint coats 45 mins?
Old 04-07-2010 | 09:53 PM
ANC297's Avatar
Bonki' Ehrite!
Yeah, those coats sound good...No, you only need 10-15 mins between paint and clear coats...I put mine on a rack from a file cabinet to paint them, but make sure you find something easily portable, and once painted bring them in for the night and leave them as is for 20-24 hours to COMPLETELY cure.
Old 04-08-2010 | 12:46 AM
kdawg8526's Avatar
just primed with 2 coats the primer turned out to be clear so i couldnt really see where i spray ill paint tommorow
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
eastcoastguy
09-24-2015 02:07 PM
datadr
09-12-2015 09:12 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Sanding headlights question
