Rotora BBK parts
You probably wont find a rotor to fit. You will have to use the rotora BBK rotor. As for pads you should be able to get other pads. Contact excelerate or rotora for pad part # and have that # cross referenced to find a pad thats the same
Do you mean you have the factory installed Brembo front brakes, as found on the 6speed manual trans cars?
Or you want to upgrade from regular TL brakes to something better?
Styl1n
i have the bbk now just curious as to where i would get the parts from when i need to do a brake change and if diffrents parts will work..thanks
Former Sponsor
If you have a ROTORA BBK the only thing you can use is ROTORA BBK discs and ROTORA pads. If you have the OE caliper then you can replace it with whatever you want.
If you need a quote please PM me with your info and zip code and what you want and I will get you a quote.
MP90 uninstalled
You can get the pads and the Rotors from Rotora or Excelerate. You only need new rotors if your brake rotors are warped. Does the steering wheel shake when you are braking at 60mph? If it doesn’t shake at all when you are braking at any speed, you don’t need new rotors so long as the new pads are only the second set of pads used on the rotors. You will need to be very gentle with the brakes for the first 500-1000 miles with the new pads on the old rotors. Either way you will need to get the Rotora parts. I also have the Rotora BBK and have already been through this. Using a different rotor or different pads is impractical$$$ and probably not possible without fabrication. Rotora will have all your answers. Call them and ask.
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
