Rotor question
Old Aug 18, 2004 | 07:34 AM
WWW
Papa Bear
Rotor question
Do you always have to machine the rotors when you put in new brake pads? I always do it but hate to wait 2 hrs for a local auto part store to machine them. Thanks.
Old Aug 18, 2004 | 09:40 AM
Tatewaki's Avatar
if you machine them, then when you put new pads on the car won't shake. The car make shake quite a bit if you don't do that, but after a day or so driving it will go away
Old Aug 18, 2004 | 09:54 AM
fsttyms1's Avatar
its recomended to resurface the rotors just so that when the new pads are put on they can completly touch the surface, there by improving braking and brake life, and to help smooth out braking
Old Aug 18, 2004 | 11:05 AM
Incubus's Avatar
...but you're removing mass from your rotors, which means they'll warp faster next time. I do advise "turning" the rotors though.
Old Sep 10, 2004 | 09:44 AM
heehaaw's Avatar
you dont need to resurface unless youve had a problem with vibrations. its not recommended to do it unnecessarily because eventually you will run out of material and need new rotors.
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
datadr
Sep 12, 2015 09:12 PM
