Rip bypass and pics of car
Purchased: April 28, 2001
thats where I saw the guy put the bypass valve in and it didnt align either. In order to get a perfect fit, you'd have to cut a chunk off the middle of the pipe (say where the A in AEM is) and put the bi-pass valve there, or dont put a bi-pass valve at all.
Re: Rip bypass and pics of car
Originally posted by Mr.T
[/B]
[/B]
Arent you suppose to put the rubber screw that came with the AEM there? Thats the stock screw isnt it....
Plus to this day i still cant get the rubber screw that came with AEM into there!!
Originally posted by BlackShadow
I guess I got the newer model of the AEM CAI. My AEM CAI came in two pieces with the bypass valve connecting the two.
Originally posted by edgalang
I think you got the 2 piece model. It's suppose to be a short ram with an option to make it a CAI. I was thinking about that myself, but I figure I wouldnt even need to go short ram or have the bipass valve installed.
Mr.T
Mr T, your AEM doesn't fit correctly and broken bi-pass valve broke because you installed it incorrectly
If you look at the instructions that came with your bi-pass valve, for one piece intakes, you have to cut the pipe into 2 pieces
Like ZodiakTL Did
http://www.acura-tl.com/forum/showth...threadid=18131
Like ZodiakTL Did
Like ZodiakTL Did
Like ZodiakTL Did
Mr.T
And do I still have to cut it in half if I just install the One piece without the bypass.
Mr.T
Mr.T
Just like failing to read instructions, I guess you failed to read my previous posts. If you install it without a bipass vavle, it'll fit correctly. If you want a bi-pass valve there, you'd have to cut a chunk off so that it SEEMS like nothing was ever added to the pipe dimention wise.
Mr.T
Doh! Sorry to hear that. I'm not quite sure what to say anymore other than I decided to get the Injen one instead. I'll share my experience with my install whenever I get around to it.
the AEM rubber material from the filter needs to be cut back an inch or two. you also have to cram it on to the end of the stack to make it fit, it will fit snugly and it IS possible to make the rubber grommet work. I have had no problems with the AEM.
