Rims
Old 01-12-2004 | 10:24 PM
RobDDD's Avatar
Rims
I have a 99 TL and the rims are starting to get pitted. Any recommendations on what can be done to fix them up? Costs? or am I stuck buying new rims?
Old 01-12-2004 | 10:52 PM
Got_3.2?'s Avatar
bring it for warranty.... thats what i did and they replaced mine.
Old 01-13-2004 | 02:58 AM
Vicman17's Avatar
If you drive on salted roads in winter, the clearcoat of your rims gets minute cracks that let the brine (salted water) seep in and come in contact with the bare aluminum. This causes the aluminum underneath the clearcoat to corrode and cause the unsightly pits and blemishes. The solution is to get the rim re-machined and stripped down to the metal and have the clearcoat re-applied. This is common on clearcoated wheels. Painted ones corrode as well but do not show it as much.
You also might want to just use your stocks for winter and put a good set of snow tires on them, then get aftermarket (or even used) rims for the summer. You would lengthen the life of the rims and tires (both sets).
Old 01-13-2004 | 12:30 PM
markhorowitz's Avatar
I simply bought a new set of OEM rims (I got the newer kind) for about 250 bucks. Re-machining them will cost more and as a prior post stated it's good to have two sets.
kev87a
11-02-2015 07:40 AM
Gout
11-02-2015 12:22 AM
kev87a
10-18-2015 02:03 AM
dirleton
20
10-16-2015 01:48 PM
Quick Reply: Rims
