rev limiter limit?
Old Aug 1, 2008 | 10:18 PM
cominfromafar's Avatar
Casper
rev limiter limit?
I searched and found another thread that said the rev limiter on the j32a2 was around 7100rpm, but that was after some mods.
I've got a bone stock 1999 tl. Today is the first time i revved it while it was in park to about 5100 - 5500rpm and quickly noticed that it was kicking or jerking back and would not go above that. You could hear and definitely feel it kicking back the rpm. I thought i broke it but then i figured it was the rev limiter that i had read about a while ago.
So my question is, what's the rev limit, while the tranny is in "park", on the j32a1 engine? And just in case, did i f-up my engine? Obviously doing this excessively is stupid. I did it four times.
Old Aug 1, 2008 | 10:29 PM
kabota's Avatar
Yep. When you are in park, you cannot rev you engine all the way. Should be in the range that you said you noticed it. No you did not mess up your engine. Thats why the engineers put in the lower rev limiter in park to keep your engine safe.
Old Aug 1, 2008 | 11:06 PM
01tl4tl's Avatar
yes there is an idiot limiter for when car is in park- 5000 rpm
The normal in gear limit is approx 7200- the tach is not an exact device, so stay below to be safe. The max torque is lower than redline anyway- so you lose power at higher revs
VTEC comes on ~4700rpm - may vary slightly by year and model
VTEC is controlled by oil pressure sensing selenoids- keep that oil clean and changed with a quality brand
Old Aug 2, 2008 | 10:59 AM
Rajca's Avatar
wham bam thank you ma'am
on my 02tl-s the rev limiter is at aprox. 7100
and on my 03tl-p its around 5800
Old Aug 2, 2008 | 12:04 PM
01tl4tl's Avatar
rajca get your car checked out- 5800 is too low- unless the tach redline mark is set there- I dont know every cars details~
The 03 may have exhaust restriction if it wont rev
I have seen othr cars- the cat gets plugged and the car wont rev over 5000
Old Aug 2, 2008 | 12:56 PM
Rajca's Avatar
my 03tl the red making starts at about 6100ish rpm and on my tls it starts at 6900ish but revs up to 7200ish
Old Aug 2, 2008 | 04:29 PM
Rajca's Avatar
correction checked again and its at 6600rpm. ill go out for a drive later tonight and see what it redlines at
Old Aug 2, 2008 | 05:36 PM
n1njai's Avatar
My car, you can see when i rev it.
http://www.youtube.com/watch?v=w4vmV72dEtI
Old Aug 2, 2008 | 05:52 PM
Rajca's Avatar
mines like that too, but in first gear id doesnt rev that high when i floor it.
Old Aug 2, 2008 | 07:17 PM
aznboi2424's Avatar
dang that sounds nice. makes me want to go from K&N+ resonator delete to CAI
and no 5k is supposed to be the rev lim in park or neutral. theres no load on the engine and reving it that high wont be good for it.
Old Aug 2, 2008 | 08:36 PM
01tl4tl's Avatar
too easy to float a valve spring and call it done for the engine~
You dont need redline in 1st either- thats way past the max power shift point to the next gear-
thats whats important if you are trying to accellerate- when the shift completes- to be exact on the rpm thats rising in the torque/power curve!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
