Resonator Removal Ques.
For those of you that have removed the airbox resonator, does your "check engine" light blink on and off for a few seconds after you start up your car? I just noticed this after I removed my resonator and am wondering, was it always like that, or because I removed the resonator, the computer senses more air intake, thus triggering the light?
Also, do we need to reset the computer a la disconnecting the battery and letting sit for about 30 mins. or so so that the computer can adjust to the greater amount of air intake and take advantage of it?
BlingBling INSPIRE 32V
When you put your key on ignition, All indicator will turn on, and turn off when you start your engine. Is that what you're asking?
I think that's normal, you're just too sensitive now.
All the indicator lights come on, and then go off, but the check engine light keeps on flashing for a good while, even after the engine is running. After a few seconds, it goes off. I thought it was normal, but I didn't remember it doing that before I removed the resonator. I am hoping it is just me, but BadazzTL has the same problem.
Yeah, I only removed the "one" resonator. I'm not a big fan of noise, so I think I will leave the one between the intake and the airbox alone, besides, I don't have a pill bottle cap to complete the mod
Peach Tea
Re: Resonator Removal Ques.
Yeah, it's the Maintence Req'd light. That's the light that keeps on flashing after the others go out and then eventually stops flashing on its own.
You know how to turn that thing off, right?? :p
Originally posted by badazzTL
haha you remember when I asked you to go check your car and see if it does that?
Peach Tea
If you mean by doing this to it , then yeah, but otherwise, I have no clue...
I thought you guys already know....at least.
Press & hold both SELECT & RESET buttom and put your key on ignition, wait till light turns off. Simple!!
Remember, you have to press & hold buttons before putting key on ignition. If you press buttons after putting key on ignition, you'll be setting outside temperature.
Peach Tea
Originally posted by songoku
I thought you guys already no....at least.
It worked for me too...songoku, you're a genius!
OMG!! don't say that!! You're making me so nervous :o
I am glad for you.
dainmezron
10-16-2015 06:56 PM
