Rervese glow gauges?
Unregistered Member
There's only a couple members old enough to remember how to do that. That DIY link went down a while ago.
I can guide you through the process, though. I was able to do it with zero experience with cars.
All you need to remember is:
-DON'T PULL ON THE NEEDLES
-Be gentle and go slowly
-You will need to drill a couple little holes to feed the wire through the cluster
-SRSLY DON'T PULL THE NEEDLES
Here's a short DIY:
-Remove the cluster from the dash (http://ledautomotive.com/guide.php?id_cms=49)
-Open up the cluster by pressing the clips. Just be gentle
-Once you get to the needles, you will have to slip the gauge covers onto the gauges
-Speedo and Tach are easy. The third is kind of hard because of the two needles
-Turn the Gas all the way up. Turn the Temp all the way down. Turn the gauge cover 90 degrees sideways
-Slip the gauge cover onto the gauge while twisting it back into normal position
-Use doublesided tape behind the covers to make them hug the gauge closely
-Make sure the needles can move freely
-You may have to lift the needles up a liiiiittle bit. Don't pull on them too hard though. I pulled really hard, and I thought I broke it. But it was fine.
-When you put it back together, you will realize there are tabs that will not fit in the cluster. Drill a small hole for that tab, and feed the wire through it.
-Put it back together
-Connect the ground and positive to the appropriate spots (I can show you later if you get this far)
-If you pull the needle clean off the gauge, the gauge becomes useless. There is no way to repair it. Fortunately, you can just replace it for $30 brand new
-It's actually kind of hard to damage it, but I just overemphasized the potential for damage so you'll be careful
Make sure you get the quality reverse gauge from eBay. I think it was like $30
Here's a short DIY:
07 TL-S
Here's a short DIY:
Here's a short DIY:
Thanks. I noticed the ebay items said they include wires and a power inverter and the such. Does that mean the brightness is adjusted using something other than the stock brightness knob? And will i have to remove/alter/add any lights already in the original cluster?
07 TL-S
The bulbs directly behind the stock gauges. I understand now though. I didnt know the reverse glow gauges used there own lihgt source. I thought the light would come from the stock bulbs
UBERTL (07-02-2012)
How/where do you ground the wires?
Here's a short DIY:
Here's a short DIY:
I'm about to drill the holes for the wires but I can't figure out how and where to plug in the wires? Can anyone explain it to me?
As for attaching the wires, what wires? The wires from the reverse glow gauges? The one should be power the other ground. The power attaches to the back side of the drivers side fuse panel. there are a few spots, one of them is power on with lights. Attach power to that one. Ground, find any suitable groud location.
w0nd3rlusTL (08-06-2012)
Unregistered Member
You shouldnt have to drill any holes for the wires.
The wires connect to certain spots. You'll have to get 2 connector terminals to crimp onto the wires. 1 will be a circular terminal for the ground, and the other will be a square like one for a tab. I'll take a picture tomorrow if I remember. Just remind me if I forget.
![](http://www.torberry.co.uk/superbasket/images/products/167/s_Ring_10_Yellow.gif)
^ For ground terminal (Black). Pop open the driver's side fusebox, and you'll see one screw with a couple wires behind it. Unscrew it, and add the ring to behind the screw for ground.
![](http://www.cybermarket.co.uk/images/product/main/783_233.jpg)
^For power terminal (Red). Might need a bigger one. On the opposite side of the fusebox, there will be various tabs to plug into. Just try them until it works only when headlights turn on. You will be upside down and at an awkward angle to get it.
I just did this and i messed up and took some needles completely off. It was a problem at first but i was able to fix all of them except my speedo. Now it says im going 10 mph faster than i actually am. Its not terrible but my advice to anyone doing this is to keep the needs on no matter what.
Unregistered Member
No, he'll have to drill a hole for each cover. How else will the wire get out of the cluster? Can't feed it behind or anything, so I think it's just best to drill through the back cluster cover.
So I take the glow off the speedo for the third and what i thought wOuld be final time and the needle pops right off. Ordering a new speedo on payday for $38, shipping included, unless anyone knows of a lower price or aftermarket gauges that look nicer than factory? I couldn't find any online. Dealership wanted $50 upfront and then wait for them to be shipped there. Cheaper and easier to get it shipped directly to me.
I'm a noob... Besides google and YouTube (ive searched) does anyone have a DIY/intro to crimping on a ring terminal? I get the concept but I'm a visual learner and need a vid or pics so I don't break anything else. (I broke the clear cover before I even got started, that was $15 and another $15 for shipping....nooooooobbbb)
Last edited by w0nd3rlusTL; 08-08-2012 at 05:51 PM. Reason: Wasn't finished typing on my iPhone
Wiring Glow Gauges or 2-din ASWC
lol@milwaukee. Did I not mention I'm a lady so no massive heavy hulk hands here
I just didn't read any instructions or pull the cluster out to see the tabs before I started pulling on the left side and it just cracked. Oh well. Got my new one in the mail a few days ago.
Update: My speedometer started working the first time I got in my car after ordering a new speedometer! But I think I'll just install the new one, hold onto the broken one and when I learn to recalibrate it I'll do that and sell it for what shipping cost me so off set my costs.
I'm installing a Pioneer AVH-P8400BH and ran into trouble with the ASWC wiring. Mountain Lion (OS X) doesn't let you print to PDF easily and my internet is down so I couldn't print the guide from the website. Anyway, a guy at customer support sent me this link about military wire splicing which I'm going to use to connect the red and black wires of my glow gauges as well. Here is it if anyone else is a noob at car wiring:
http://www.backinblackgp.com/Tap_And_Splice.htm
I connected the wires according to the instructions (black to another black and red to the red on the dimmer) and not only to do the glow gauges not work but neither does the regular glow. I'll probably take off the butt connectors and reconnect them and add some wire in for slack but this is pretty frustrating.
mrkingstonvi
02-22-2016 01:53 PM
