required maintenance
Ok so i got this Req'd Maint light flashing for about 5-10 seconds every time i start the car and I wanna know if this is normal since I just went a little over 101 miles? or if this is something serious since I still havent cleaned the EGR cuz its been too cold and its snowing again. I cant notice any difference in performance or gas consumption or anything like that.
Porkchop Sandwiches!
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
If you want to reset it you have to hold down the the two buttons on you dash (trip and reset or whatever theyre called) then put your key in and turn it to the on position, but dont start, after 10 or 20 secs it will clear out.
WNC Real Estate Sales99TL
just push and hold the trip and reset buttons in, then while holding them in turn the key to the run position. Continue holding them till the Maint req lite goes off (about 10 seconds) You are supposed to reset it at every oil change. Its the reminder to change your oil when it goes on solid. It will flash on start up when its getting close
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
its just the oil change reminder light- starts flashing about 6000 miles since last time it was reset- has no bearing on condition of anything- it gets pretty anxious at 7500 miles too!
joflewbyu2
08-18-2019 10:38 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
