Replacement AV6 Transmission
My replacement transmission on my 02-TLS is finally starting to go out (replaced at 100k, now have 235k). I want to extend the life of the car by a few years by replacing the transmission. Looking around I see that most people are using the Honda Accord 06-07 transmission as a replacement.
I'm having a little trouble verifying if the replacement transmission will fit. Can someone confirm that this is the right one?
https://www.ebay.com/itm/2003-2007-H...ated#vi-ilComp
Thanks.
Thanks.
On second thought I may just go with one made for the TL. These are from japan with less than 55k on them.
https://www.ebay.com/itm/2000-01-02-...da1gk1&vxp=mtr
Here's another one that actually states that it will fit 04-06 TL. Look at the 'Item Description' tab.
Sorry, wrong TL. You have a 2nd generation. I think this will work for you; however, I not positive.
https://www.ebay.com/itm/2003-2007-H...taeOOG&vxp=mtr
zeta (05-08-2018)
That very more than likely is the correct transmission. I would verify with the seller that the transmission code is correct before buying. BAYA is the most recent compatible transmission that has all of the redesign features that corrected the fatal problems in our 2G TL transmissions. Don't let the seller convince you it's okay to buy anything other than a BAYA transmission.
whitetiger5 (09-06-2018)
As Chojun advises, the issue here is, that you want an 06-07 Honda Accord V6 BAYA code transmission, ONLY, PERIOD! Be LEARY, when the listing shows 03-04-05-06-07 Honda Accord 3.0L 5 Speed Auto Transmission) The 03-04-05 Accord transmissions exhibited the same problems, and issues, as the 2G TL transmissions. While the 03-04-05 Accord unit may well fit, and work, it is still unreliable. What you may want to do, is check-out, Car-Part.com, and or HollanderParts.com. Both providers show, not only pics. of many of their cars, along with pics. of the illuminated cluster, which displays actual mileage. These type sites, also allow you to shy away from cars, which were HIT IN THE FRONT! They also list the VIN, in case your interested in checking out the car's maintenance history.
Secreta Manny
03-02-2019 09:40 AM
