Removing the storage door-Rear of the center console
My kid stored a golf ball in the ashtray/storage door in the rear of the center console. It sounds like it's loose in the center console. I can hear it bounce around when i turn.
Is removing the door the only way to access this area?
Now, i'm not for sure it's the golf ball i hear. It's what I'm guessing. LMK if it could be something else.
I just want access to check it out.
thanks
joe
thanks
joe
is the door stuck closed? im not sure if you can get to it from the bottom side or not. but you could pull up on the 2 wood (center console pieces) and rempve them. remove the (6 i believe) screws and then remove the 2 screws under the little carpet piece in the bottom ov the console. you will need to slide the whole thing to the rear of the car (about 2-3 inches) and unclip the wire for the center power plug then you can remove the whole thing.
hope that helps
hope that helps
thanks
the door is not stuck. i was hoping that would be the easy way in. the only part that worries me is taking off the wood pieces. what are the chances i'll break something? and what is the easiest way to remove the wood pieces?
joe
joe
SidhuSaaB
05-30-2020 12:40 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
