Removing rear seats
Old May 17, 2004 | 01:49 PM
Removing rear seats
Tried searching for this...to no avail. (99 TL)
I'm looking to remove the rear seats, the passenger side in particular to access the stock amp and sub wires and whatever else is back there.
Thanks in advance.
Old May 17, 2004 | 01:53 PM
Seotaji's Avatar
The seat bottoms are held in with a long bolt. You can find it near the seat belt buckle on the driver side. Let your fingers do the walking and feel for a bolt, when you unscrew it, the seat should just pop up and out. The seat backs are held in with bolts on either side, which will be easy to find once you remove the seat bottom. The slide up and then out.
Hope that helps.
Old May 17, 2004 | 02:03 PM
Thanks for the quick response!
Old May 17, 2004 | 03:05 PM
jg123's Avatar
I just did this last night. The first bolt you need to remove is on the center passenger side. Feel for the two metal bars going down into the seat bottom to know you've found the right one. And remember, you don't have to remove the seatbelt bolts. If your reaching for the socket > 10mm you're loosening the wrong bolt (I know. I took off the seatbelts...).
Old May 17, 2004 | 09:28 PM
actlsub's Avatar
3 bolts, all 10mm, one in the middle on pasenger side to remove seat and two on either side to remove back. Remove the bottom seat first. Back of seat has hooks on top, you have to push it up and out after bolts are off.
Old May 20, 2004 | 03:27 PM
Thanks guys...I'll be doing this in 5 minutes.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
d.lim
Sep 15, 2015 08:54 PM
EE4Life
Sep 11, 2015 10:13 PM
truonghthe
Sep 7, 2015 11:17 PM
