Removed drivers seat...now not working.
Old 03-21-2014, 12:27 AM
Levithan9's Avatar
Well, as the title says, I removed my drivers side seat to get the bottom part off and send out to a fabric shop so that they could put a new leather piece in.
It looks good, by the way...
But when I got it back and installed the lower seat to the frame, then installed it into the car, it didn't move...AT ALL !!
I took the seat out and made double sure and triple sure that I didn't leave anything disconnected. I didn't.
I looked up a pin out test for the switches...going forward and back....up, down and what not. I got power coming to the switches, and power going out to the power seat module....but no movement.
Has anyone ever experienced anything like this? I don't think removing a sea and re-installing it should break it.
Let me know what you guys think...need some help on this one.
Old 03-21-2014, 03:21 AM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
Check fuses? #2 and #4 on the Passenger Fuse Box protects the Seat Motors..
Old 03-27-2014, 09:44 AM
Levithan9's Avatar
Ok...i got the seat to work !!
Turns out that the 3 connectors on the side of the seat for the forward/back up/down and recline are all the same. When i removed the seat bottom, i removed the pigtail from the recline motor. After a week at the fabric shop, i had forgotten where it went. And it didn't help that the wire harness ON the recline motor is BLUE, and the connector for the recline BUTTON is BLUE as well. I had the connectors on backwards.
After switching them out, it all works fine.
Old 03-27-2014, 10:30 AM
M224armstrong's Avatar
Pics?
Old 04-06-2014, 10:23 PM
9th Gear
abnormalwrench's Avatar
I did the same thing also. Pretty horrible design, but at least nothing blows up when you do it on accident.
Old 04-07-2014, 10:59 AM
Levithan9's Avatar
You see the blue connector? Well, the connector going to the recline switch on the side if the seat is blue as well, so common since dictates that a blue female plug should go in a blue male connector.
Not so with this car. The white connector goes into the blue connector for the recline motor. If you get them backwards, nothing will work.
Old 04-07-2014, 12:08 PM
Received 5,411 Likes on 3,702 Posts
I might have to check this on mine. My driver's power recline hasn't worked in the almost 4 years I've had my car. Luckily, it's stuck in a comfortable position.
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
BoricuaTL
04-08-2016 01:08 PM
01CLOwner
10-09-2015 01:07 PM
CadiGTi
09-14-2015 06:37 PM
Quick Reply: Removed drivers seat...now not working.
