Remove side mirror, do I need to take the door panel off too?
Old Mar 22, 2010 | 04:37 PM
Deepsiix's Avatar
2000 3.2TL
I'm trying to replace my side mirror assembly on the passenger side. I can get the mirror off fine, but I can't see where to unhook the wire going to the mirror either in the mirror or where it goes into the door panel. Do I have to take the door panel off to unhook it?
I can't get enough slack to pull it away from the door enough to see inside the mirror and maybe pull it out from there.
Old Mar 22, 2010 | 05:51 PM
Rajca's Avatar
wham bam thank you ma'am
u need to take off the door panel.
Old Mar 22, 2010 | 08:54 PM
mlrskn06's Avatar
u should take pics and make a DIY on this
Old Mar 22, 2010 | 09:09 PM
assclown's Avatar
2000 acura tl FPR
shouldn't be too hard
OP what are you doing? where you in an accident or are you upgrading to TSX mirrors or something?
Old Mar 22, 2010 | 09:35 PM
dudeinaTL's Avatar
Are you talking
1) (Heater) wires going from the mirror glass to the mirror assembly, or
2) Wires going from mirror assembly to inside the car?
If #1, you disconnect the wires from the back of the glass. Might be a little tough, but the connectors on the wire slide into the terminals on the back of the glass.
Old Mar 23, 2010 | 02:09 PM
Severin's Avatar
Actually, how do you remove the driver side mirror glass? My heating element does not work and I want to see if it a connector or element issue.
Thanks!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
