remote program related question..
Old Mar 28, 2006 | 03:59 AM
SSTLS408's Avatar
"IRidEDuMpEd" User
well i programmed the remote that i got from ebay quite successfully, but besides opening the locks and unlocking, isn't the trunk open button suppose to work as well? Is there another programming process i have to complete? i'm just wondering cuz i noe it should...thnx
Old Mar 28, 2006 | 10:29 AM
darshan_patel's Avatar
Can u post how did u progrom that remote? does the ID on the remote has to be the same on both? i wanted to buy a remote for my TL from ebay but fatty said some kinda ID has to be the same..so was wondering .!!
and i think fttysms....knows and he posted the instructions bout the remote programming.
Old Mar 28, 2006 | 10:47 AM
georgy_d28's Avatar
Keyless entry Remote can be program by doing the following, you must program all remotes at the same time,
else the remotes not included in the programming will not work.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same
but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or
onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter
lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter
code is stores. Make sure you program all transmitters you want working within 10 seconds of each other.
Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
***make sure the serial number on the backs match.....Program at your own risk***
The TL keys have the chips in them, I found this but havent tried it yet..let me know if it works for you:
Originally Posted by TL_Fo_Life
1...your new key
2...a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to
floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait.
the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light
is off, car should start.
Old Mar 28, 2006 | 11:11 AM
oops sorry i thot it was the guy with the six speed tranny posting the instructions.!!
umm how do u know if it has the same ID ..before ordering from ebay?
Old Mar 29, 2006 | 03:35 AM
Topher707's Avatar
05 Acura TL: a-spec
greg: I got one remote with my car and 2 keys.. i just ordered another remote off ebay. Are you saying that i have to program both remotes again? or just the new one? THANKS
Old Mar 31, 2006 | 09:52 AM
georgy_d28's Avatar
Yes you have to follow the instructions, then when you get to this step you must aim all of the remotes you want to program towards the glovebox area
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
