Redline WaterWetter
Received 1,080 Likes
I'm using it but I did the following all at one time, so I couldn't tell you.
Mugen thermostat
Mugen rad cap
Mugen radiator fan switch
Fluid flush
Redline WW
Mugen thermostat
Mugen rad cap
Fluid flush
Redline WW
Here is a cut and paste from RedLine's web site about WaterWetter.
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
http://www.redlineoil.com/whitePaper/17.pdf
http://www.redlineoil.com/products_c...p?productID=53
Mugen thermostat
Mugen rad cap
Fluid flush
Redline WW
Mugen thermostat
Mugen rad cap
Fluid flush
Redline WW
vpasla1
09-17-2016 07:24 PM
D-Rob
62
01-05-2016 11:44 AM
EvilVirus
12-10-2015 07:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
