Rearview Broken!
Rearview Broken!
MY rearview mirror broke, butnot totally it is hanging there limp.....I was wondering what kind of options i had to fix it besides just going to the dealer because they quoted me $120....any suggestions will be welcomed
when i say broken in my case the mirror itself is fine, but it won't sit perpendicular with the floor of the car it just faces down so it isn't functional, but the dimming and all works just doesn't sit right
you cant use crazy glue. did it break from alot of bass in the car? mine did. all mirrors pivot on a ball joint. our mirrors are connected to that joint with a female like socket and there is an o ring made of metal(that is what it feels like) that fits in this order:
(oring) -O )--||
the back of the female socket has teeth, sort of, that the o-ring snaps into and provides that tight fit. on my mirror, a tooth of that female socket broke. the o-ring was simply hanging there on the ball side. i pushed it back on and it kind of snapped back in place, but every once in awhile, it falls back off and i have to snap it back in place.
see if that is the problem. you have have to replace the mirror if it wont snap back on.
(oring) -O )--||
systek you're right on the money and how you described it and it won't snap back, the ring is just broken off and i think it is from my bass...i am lookin for some kind of putty or molding clay to fix it with...thanx for your help
i don't think you can fix it other than replacing the whole thing, the part that got broke off is belong to the housen, i know cuz it happen to me. I had the dealer replace it under warrantee. and i don't think that cause by "bass" unless the acura OE Sub is strong enough to cause it!!
i also managed to break the plastic windshield mount to my bel radar detector... :wow:
how is that for bass in ur fass
You may be able to contact Magna Donnelley (manufacturer of mirror) to obtain a replacement at no charge. My rearview started to leak that electrochromatic fluid internally, causing the day/nighttime view to look real fuzzy. I called the manufacturer and they sent me a new one for free. If you go to their website you can locate their contact information. Good luck.
Jul 16, 2017 07:33 AM
dainmezron
Oct 16, 2015 06:56 PM
