Rear Seats?
Old Aug 8, 2002 | 10:55 PM
snapple's Avatar
Rear Seats?
How do take the back seats down? I'm gonna change my stock sub and I don't know how to get the rear seats down. Anything would help. Thanks
Old Aug 9, 2002 | 01:51 AM
drcookie's Avatar
Snapple,
Do a search in Audio and Electronics section. There has been some discussion about removing rear seat in TL-S.
It's really late and I am too lazy to search for ya.
Good Luck.
Cheers !!!
Old Aug 9, 2002 | 02:27 AM
randomwalk101's Avatar
Re: Rear Seats?
Snapple,
To remove the rear seat, you need 12mm socket/racket with an extension. But don't quote me on the socket size though . Anyways, reach in on the right side of the REAR middle console/cup holder thingy, sort of pull the seat back and the seat bottom apart a little bit, you'll see a black bolt. Remove this bolt. Grab each side of your seat bottom and pull it straight up to unhook the bracket. Don't worry, the bracket is HUGE...won't break. You'll break your arm before that thing will break. Lift the seat bottom and remove it from car. After the seat bottom is out, three more bolts will become visible..same size as the previous one.. Remove them. Pull the seat belts behind the seat's back and lift the seat's back straight UP. There might be some resistant but just wiggle around and lift it up..it'll come off. Again, there are a couple of bracket holding it in place..bracket is huge..so you don't have to worry about breaking anything. Notice the seat's back has a metal bar that is very SHARP. Be very careful with it or you will cut/scape your car. Anyways, once you lift the seat back's up, remove it from vehicle and you will se the stock sub's amplifier and everything. THe stock sub amp is TINY. You might need a microscope to see it j/k Good luck.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
d.lim
Sep 15, 2015 08:54 PM
EE4Life
Sep 11, 2015 10:13 PM
