Rear rotors???
B93P TL Owner
Rear rotors???
My car vibrates through the floor when I apply my brakes heavily at highway speeds (60+ mph). No vibrations or shimmies through the steering wheel though. Does this mean that my REAR rotors are warped? Below 60 mph I do not hear or feel the vibration at all. Thanks.
@ slide or die @
stock rotors...prob warped...not just rears. when you break and the car vibrates, does your steering wheel vibrate. are your breaks inconsistent (not smooth) when you break at a light or a stop sign?
if aftermarket, then they either suck you you didnt install em right
I believe it's usually the fronts that go out-of-true fastest. Find a shop that you trust enough to inspect them all before resurfacing any. I prefer a shop that turns the rotors right on the car versus sending them out to a machine shop.
TL Brake Problem Woes!!!
I've got an '02 TL w/ 55k miles. 1-1 1/2 yrs ago, when I had 30-35k miles I had the dealer take care of a problem I was having - car would shimmy and shake (could feel it thru the steering wheel too) and they replaced the rotors saying they were experiencing lots of problems w/ "warping rotors".
The brakes have been fine and I haven't had any problems since.......up until a week ago. Now (again) I' experiencing the same problems.
My question to you guys is - what's the likelihood of the dealership redoing my rotors again for no charge?
Also, do I even want to go w/ the Acura rotors again? I'm thinking I should go aftermarket.....and if so what should I go w/ (slotted or drilled.....and what brand)?
I guess I'd do pads @ same time too......which kind of pads?
Thanks for your help.
@ slide or die @
they will do it free if you ask nicely...if not, then get aftermrkets...SLOTTED ONLY...drills just keep the rotor clean, high chances of cracking, reduced performance (takes away from rotor integrity ~ cooling) but looks good better...slotted+drilled is even worse
brand is up to you...change the pads ~500miles AFTER you've changed rotors (break in period...recommended to bed the pads
glad to help
glad to help
