Rear Engine mount
Old 04-14-2013, 05:05 PM
Bonki' Ehrite!
ANC297's Avatar
Rear Engine mount
I cant seem to find the DIY for the rear mount. Anyone?
Also, I have read some great things about innovative mounts, however I see no second gen tl on their site inventory, do we just use 98-02 Accord mounts?
I am between innovative and DEA from ebay, because there is a 5 piece kit for $107 has all the mounts, has anyone used the DEA mounts before? How is the fitment and quality? Any huge downfalls of no vacuum assist?
Old 04-14-2013, 06:43 PM
victus1's Avatar
https://acurazine.com/forums/showthr...diy+rear+mount
It's an easy job if you have the right tools. I used the DEA (motor king), check my link.
As an alternative, undo all the engine & tranny mounts and jack up the engine to remove just the rear mount without removing the mounting bracket.
Old 04-14-2013, 07:29 PM
MilwaukeeDave's Avatar
Xlr8 ftw!!
Old 04-14-2013, 08:34 PM
Bonki' Ehrite!
ANC297's Avatar
Victus, thanks thats the thread I was looking for.
How is the quality of motor king/ DEA mounts? Fitment as good as oem?
Old 04-14-2013, 10:40 PM
victus1's Avatar
Yep, fitment is identical, no problem installing any of them, including the tranny mounts. Keep your old rubber vibration isolators for the front & rear mounts just in case yours don't come with any. You need to install these properly seated otherwise you will get vibrations at idle, as others have noticed. The quality seems the same as oem since they are the same design. The sloppiness of the engine under acceleration went away after I installed them. Very firm now.
Old 04-15-2013, 08:30 AM
3.2TLc's Avatar
Being a generic copy of the OEM's will work in the short term, but if you are willing to spend the extra bucks....then you can expect better durability.
Another thing to consider is your driving style and if you are going to require better control of additional torque with future upgrade performance mods.
Bottom line is the time involved with installation, you save half a day's worth of labor expense by "DIY".....which would justify the better mounts, IMO. Your choice !
Old 04-15-2013, 08:54 AM
Bonki' Ehrite!
ANC297's Avatar
What do you mean properly seated?
Old 04-15-2013, 09:11 AM
victus1's Avatar
You will see that when you install the mount bracket over the rubber isolator, it may misalign it and you will get contact with the metal of the mount. Just watch out for this. So when you tighten it down, the rubber isolator is in place and hasn't shifted. That goes for both front & rear mounts. Other than that, it's straight-forward. The lifetime of these mounts would probably be similar to oem, which ain't great. But for me anyways, I can easily reinstall them if I had to years down the road....and there is no way you can beat that price.
Old 04-15-2013, 10:34 AM
Bonki' Ehrite!
ANC297's Avatar
Oh ok I gotcha. and yeah, the price is great I will order tonight and installation should be easy for me.
Old 04-15-2013, 09:30 PM
Bonki' Ehrite!
ANC297's Avatar
Just ordered DEA set
Old 04-23-2013, 02:54 PM
chris03tl's Avatar
Is it possible to tell if the isolators are there and correctly installed just by checking out the mounts?
Wifes car has been vibrating at idle ever since the tranny was replaced.
I figured one of the mounts was toast by now but the point you made about the isolators has me wondering. If I can check them without removing the mounts themselves it might prove to be the issue.
Thanks.
-Chris
Old 04-23-2013, 04:52 PM
victus1's Avatar
To replace the tranny only the front mount needs to be undone to remove the crossbrace. Get a flashlight and check if the piece of rubber is installed on the top of the front mount where the bracket sits. You can feel it with your hands. Maybe they forgot to install it. Also, check the 2 tranny mounts to make sure they didn't forget to tighten them or that they're not torn. Remove the driver wheel to check them easily.
Old 04-23-2013, 07:48 PM
chris03tl's Avatar
just took a look/feel...the only thing I can feel that is rubber is what i think is the mount itself. Between the bracket and mount I dont feel anything soft. The top surface of what I can see is definitely metal
Taking a look here: http://www.acuraautomotiveparts.org/...s=&view=normal
Is the isolator part 5? (conveniently not even listed for order!)
Old 04-23-2013, 08:10 PM
chris03tl's Avatar
No edit button?
It looks like part #5 might be an older style mount? Might explain why its not listed for order. Part #34 looks closer to the mount on our '03. Wondering if Acura dropped the whole isolator thing?
Didnt look at the tranny mounts just yet, didnt have time to pull the wheel off the car. Hopefully this weekend sometime (timing belt getting replaced Friday, maybe Ill have the shop take a look)
Old 04-23-2013, 10:58 PM
victus1's Avatar
Hmmm....it looks like they forgot to install it for you.
No, the dealer didn't drop the rubber isolator. It's an intergral part of the front and rear mounts.
I thought you can separately order it. Did you call some dealers? If you have a good relationship with a dealer, I'm sure these guys can get one for you. They have ways of getting stuff if they want. Another option is to try some of our sponsor dealers here. They may go out of their way to get it for you.
You can also make your own from a piece of 1/4" thick semi-soft rubber.
drone619
01-26-2016 07:09 PM
wilztlxs
12-01-2015 09:16 AM
BKSleeper
10-07-2015 10:20 AM
Aging-Hacker
10-05-2015 11:44 AM
sockr1
10-01-2015 01:31 AM
Quick Reply: Rear Engine mount
