Rear Calipers
Old Jun 7, 2013 | 11:46 AM
Nicks2001tl's Avatar
Rear Calipers
Will be changing out rear calipers. Will the legend calipers fit the rear?
Old Jun 7, 2013 | 11:55 AM
TheMightyQuinn's Avatar
Registered Nonmember
Unless you have a problem with them, just keep the OEM ones. I believe the legend used the same rear calipers.
Since something like 80% of your braking is performed at the front of the vehicle, there isn't much improvement seen from upgrading the rears.
Old Jun 7, 2013 | 12:29 PM
Gabru678's Avatar
I think he means to say will the legend calipers mount to the rear calipers?
Nick: I dont think so You will need a custom mounting bracket for the caliper for it to fit properly.
I think that if my brakes get upgraded later I will just put Legends up front. and then try to get the OEM front ones mounted to the rear.
Old Jun 7, 2013 | 12:43 PM
Just going for preventative maintenance.
But if I can mount the fronts to the rear and replace the fronts withdrew legend calipers that would be something I would do.
Old Jun 11, 2013 | 04:44 PM
01tl4tl's Avatar
NO!!!!!!!!!!!!! fronts are way different than rears
use correct TL rears
see my many brake thread instructions on bleeding after caliper install
Old Jun 12, 2013 | 07:38 PM
Gabru678's Avatar
Oh really?
Well that's good to know.
I always just wondered if something like that would be possible.
Old Jun 16, 2013 | 07:06 PM
It is an interesting idea. If the brackets fit or can be retro fitted it would make a lot of sense and save some pennies and better braking.....
Old Jun 20, 2013 | 11:35 AM
01tl4tl's Avatar
more rear brake would cause the car to come around--ie: spin out under hard braking
current percentage is about 70/30 brake bias
see race cars lock up the rears and go straight off into the wall??
too much rear bias
Old Jun 20, 2013 | 11:37 AM
01tl4tl's Avatar
want better braking? buy badazz Front rotors and maker matched pads
I use racingbrake.com 1 piece slotted rotors, legend calipers, and ss brake lines
its a stopping machine
keep brake fluid flushed- replace every year to 3 years max!!
Aug 15, 2019 12:58 PM
drillzzz
Jul 28, 2019 06:30 PM
yesSIR-S
May 13, 2016 05:42 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
Ny1718
Sep 11, 2015 09:21 AM
