Rattling Noise
Rattling Noise
I have this rattling noise coming from the back of my car that I can't pinpoint. I was hoping some of you could help. It's this noise that sounds almost like you're tapping on a piece of plastic. It's definitely coming from somewhere in the back. The noise doesn't make a sound when it's raining or if it's very humid. I think the moisture is making whatever is making the noise to expand. Thanks, for any help.
mawaru,
I've found that the torsion bars for the trunk lid have a little play in them where they attach to the rear deck. You'll see what i mean if you look just aft of the subwoofer. I stuck a piece of cardboard in there to tighten it up a bit.
Hope this helps
Iggy
Hope this helps
Iggy
This could also be sound resonating through the overhead liner from the well documented sunroof/overhead rattle. We had that one fixed at the dealer but it really sounded like it was coming from the rear lid/sub woofer area. If you do a search on "rattle" you will learn all you ever wanted to know about the most common TL rattles and possible fixes for them.
I had the same problem and fixed it easily
Look up at the middle of the headliner while sitting on the rear seat. There is a plastic cap/screw type thing. I took that screw out, greased it up really nicely and greased up the socket that it goes into and the sound has been gone every since.
To make sure its the same sound, does the sound go away if you push up on the headliner while driving? If yes then its the same sound that I experienced.
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
