Raising the Idle
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I always thought my TL idled low. Sometimes at lights, my whole car shakes which should not happen at all. Also, when I start a warm engine, NOT ALL OF THE TIME, but about 75% of the time, the engine idles really low and again shakes. I want to know which of the two cables I have to adjust? Which one for idle and what does the other one do?
Thanks again,
the kid who asks a lot of questions
Thanks again,
I agree with UW TL...
Are you sure it's the idle and not cheap gas? My TL did that when I used Mobil gas when I first bought the car. I changed to Sunoco 93/94 and never had the problem again.
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank>
</A>
![](http://www.adamoski.com/images/Acura3200.jpg)
Originally posted by SL1200MK4:
Do you have a 2000 TL by any chance? That sounds like the problem people always have with the ECU computer bug...
Acura3200, I always use good gas 93. The companies vary. I usually use Mobil, Exxon, and Amoco. I think I'll give Sunoco a try. The problem is there are not a lot of Sunocos around here so I don't use them.
its not the cables you adjust, there is a valve on the throttle body i think. if you still want to do it, let me know and i'll "make an effort" to look it up it the helm ![](http://www.acura-tl.com/ubb/smile.gif)
id let the dealer sweat over it
You cannot adjust the idle on any Acura TL. It is controlled by the engine computer. If your car is idling roughly or too low, have your dealer look at it. Any tampering may void your warranty.
Yep, I agree with that..... Plus you don't pay a penny for it....
What RPM does your car idle at?
You may want to try disconnecting the battery for 5-10 minutes. The ECU will then have to "relearn" the car.
Does anyone know of an easier way to reset the ECU then pulling the battery?
DerrickW
11-15-2015 05:52 PM
