radio pop
Old Mar 7, 2007 | 12:15 PM
poohlikeshunny's Avatar
Money is funny.
radio pop
Ltely my speakers have been suddenly making this "pop" noise. It seems to be random, and doesn't matter if it's the radio, cd, or tape. what could this be?
Old Mar 7, 2007 | 07:47 PM
Tom Blasing's Avatar
is the Mighty Favog
If it's when you touch/turn the volume knob or any other knob it's probably just a dirty pot. If it just happens out of the blue then there is probably a bad ground or something is shorting out (arching) inside the one of the units.
Or it could be a capacitor going south by dumping it's load into the stream.
Old Mar 7, 2007 | 09:27 PM
uncald4's Avatar
Former Sponsor
Ford's are know for the volume pot going bad. The "popping" is where it starts. Most factory decks with volume knobs make some type of noise after a few years. It is more appearant in amplified systems. My factory TL deck makes a pop noise also. And the volume fluctuates if the pot is in between notches.
Time for a double din screen!
I know we're not talking about Fords. I was just making a reference.
Old Mar 8, 2007 | 10:05 AM
Money is funny.
what is a "pot" sorry, but I know little about audio setups...I don't use the volum or anything, it just pops every so often randomly...loose wires perhaps?
As for th double din screen, I have an avic D2 i bought off ebay for 15 bucks that doesn't work. I bought it for shits hoping my buddy and I could find out what's wrong..but we cn't figure it out...
Old Mar 8, 2007 | 10:29 AM
MOBB's Avatar
It happened with my stock sub, It sounded as if it was gonna blow up. I pulled over and found there was some loose wires, and a wire was touching the body of the car causing my lights and everything to abruptly stop working.
Old Mar 8, 2007 | 11:20 AM
uncald4's Avatar
Former Sponsor
A "pot" is short for POTENTIOMETER. It's a variable resistor. In your car it's a volume knob. In your house it's a dimmer switch or heater knob. It's the speed setting on your vibrator.
From your explaination it does sound like a loose or grounding audio wire. I'd take your rig into an audio shop. A "good" audio shop.
You could probably have your Avic D2 fixed for under $100. Even if it costs you $300 bucks it's well less than you would have spent for a new one.
Old Mar 9, 2007 | 08:01 AM
Money is funny.
Awesome feedback, thanks!
mobb, was it fairly wasy to take apart the sub? can you do it from the trunk or do you have to actually atke it apart?
uncald4, how do you clean the "pot"?
Old Mar 9, 2007 | 09:55 AM
uncald4's Avatar
Former Sponsor
Funny...
Pull the volume knob off carefully. Don't use a tool. Use your fingers.
Spray the "fuzzy" parts off with compressed air. Like you would use on a computer keyboard. Be thourough. This should be sufficient.
To clean it "properly" you would have to take the whole deck apart.
Old Mar 9, 2007 | 12:12 PM
Money is funny.
awesome! thanx! I'll be doing that this weekend and hopefully solving the problem!
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
Fool
Mar 10, 2016 08:42 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
