Radio control on steering wheel...
Lately I've noticed that the radio controls are not working as well as usual. I have to push the volume control repeated to get it to work, and sometimes that doesn't even do it. The other day, when I pressed the volume button, it changed the radio station. It's beginning to piss me off. Has anyone else experienced this? Any suggestions?
Peter.
Peter.
I had this problem on my 2000TL. It got to the point that it would change channels if I pushed the volume doan button, get quieter if I pushed the volume up button, etc, etc. - they had to replace the entire steering column to repair. It was covered under warranty.
Re: Radio control on steering wheel...
Peter.
Peter.
You didn't spill soda into your switch assembly, did you? It sounds like a dirty switch contact to me.
jdl75:
How long did this whole process take? Did they have to keep your car for a long time? Or did they order the steering column while you kept your car?
Thanks,
Peter.
Recently I switched steering wheels from stock to wood. If you want to fix it it's fairly easy. Disconnect the battery, wait three minutes. Pop off the small trim covers on either side of the steering wheel at the base. Use a t-30 torx bit to remove the two screws (T-30 bit available at any parts store, about $2) and then gently pull off your steering wheel cover. The air bag is in there so be careful - then with a small phillips screwdriver unscrew the old switch after you disconnect it and replace it with you new one. Slide your cover back on, put your screws back in either side, reconnect the battery and reset all your radio stations (get your code first) and you are good to go. Look in your owners manual in the audio section to use the coding process.
Puma Jim
20
Oct 20, 2016 11:59 AM
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
