Radiator in the air intake?!?
You can turbo anything
Took all my stock intake crap out to make room for the intercooler piping, and put on a custom short ram intake. I had to reroute some hoses because there was a mini radiator in the intake. It made the air box hot as hell to.
What did you guys with CAIs do with it...I just took it off, and used one of the bigger hoses to go right from the water pump to the throttle body, and took everything else off...
If you do this tho, make sure to use the hose with the big brass coupling on it, cuz I think that might be a pressure regulator or something.
Oh, and if someone call tell me how to post a picture in the thread, I will put a pic of the thing up on here.
Boomer SOONER
that is a small radiator and I think its only in the '99 and maybe '00 TL's. its in your manual if you want to read about it, its to warm up the intake air when its below like 25 degrees. Anyway, when you get a new intake, you just bypass it (connect the hoses together)
Boomer SOONER
Originally Posted by speedr73
Oh ok...wasn't too sure...so then that little spring loaded flap opens up when the 25 degrees is hit?
Originally Posted by ou sig
ya pretty much, the exact number is in the manual...but thats the idea (warm the intake air!!!!!)
rcs86
08-02-2016 06:52 PM
