Quick NGK question....
#42
After seafoaming I really didnt take a long drive just revved the car in my apartment parking lot for 5 mins.
Also I changed all the plugs. IT really didnt tak that long for the rears. THe only problem I had was one of the plugs was broken and it was a bitch to get that out. OTher than that its alll good. Also My idle is still rough and I really didnt notice much of a differ with the new plugs.
Also lets say one of the plug isnt working? How would I know would the CEL come one?
#45
After seafoam you MUST drive the car to super heat the solvent and carbon that is now loose and burn it off- blow it out.
If that pic was taken right after, that would explain the coloring
You still need to take it for a 4000 rpm run and use vtec several times- really get it worked thru.
Gets better with time too.
Kris said the IAC is right below the TB (maye part of it?) and is held on by 2 screws- Remove and clean- lightly lube with WD40 and reinstall.
#46
WNC Real Estate Sales99TL
I cleaned the IAC when I cleaned my EGR port. Idle is smoother. It was dirty. I'll be posting pics soon and my own experience in cleaning the EGR port. Wasn't hard to do and the car runs much better.
#48
is there a way to do this without taking the TB off and what all is connected to the IAC
#51
#53
V8 will idle smoother and v10 will idle smoother yet. They are inherently balanced better by design.
The TL should be pretty smooth. If you feel any thing it could be any number of things, from plugs to a sensor and a very likely cause- motor mounts.
#60
THe hose that goes into the TB from the air box, has a thing that is attached to the bottom, now my question is why does it have oil in it?? Its clean oil to.
https://acurazine.com/forums/showthr...ghlight=filter
#63
Green? Looks like coolant. Is it coolant or oil? There should be No liquid in that. Period! Thats the resonator.
#68
Originally Posted by fsttyms1
Stick with the OE plug
J32-A1
NGK- PZFR5E-11
J32-A2
NGK- PZFR6E-11
J32-A1
NGK- PZFR5E-11
J32-A2
NGK- PZFR6E-11
NGK Iridium plug 4095 IZFR6F-11 .044" SOHC $11.71
NGK IX iridium 6441 ZFR6FIX-11 .044" SOHC $6.95
Anyone know the difference between these two models or have used either of them?
#69
I am running the NGK Iridium IX for 6something each from kragen
Many members are on one or the other- as long as NGK you're OK!
Kris prefers the Platinum, I am of the Iridium believers
#71
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
How do you like the NGK Iridium IXs, 01tl4tl? Do you know what the difference is between the two NGK Iridium offerings to warrant a $5 difference each?
I bought my TL-S last June, and I don't know if the previous owner ever did any maintenance on his own. I don't think so because I was the first to replace the in-cabin air filter a couple of months ago (man were they dirty!) There's 78k on the odometer and I read that Kris recommended changing them at 80k or so.
#72
Got the Iridiums here...
NGK Iridium IZFR6F-11
or the
NGK IX iridium ZFR6FIX-11
How many miles did you have on the odo before you changed plugs? Did you notice a difference in either power or gas mileage?
#74
Yes I did notice a slight improvement in gas mileage after install of Iridium plugs
and butt dyno of better accelleration
OE plugs had 70 k miles on them, definite wear- still working bit not at FULL performance
with gas prices rising- plugs are cheap- so get the good ones!
