Quick help!!!!
Old 04-17-2014 | 09:50 AM
rellgeta's Avatar
Quick help!!!!
99 acura tl.. when I got in the car this morning NOTHING WORKED... well i was able to start the car and drive and the radio and the heat workes but.... WINDOWS, DASH, ANY BUTTON NEAR THE DASH (CC,TCS BUTTON) and intrument cluster and i could not get out park without the override feature.. now i changed the ignition switch lately could that be the culprit??
Old 04-17-2014 | 10:50 AM
rellgeta's Avatar
UPDATE!! well it is not the switch cause i just switched the old one back on and it is doing the same thing smh... now i am stuck!!!!
Old 04-17-2014 | 12:02 PM
03blackbeast's Avatar
Have you checked all of your fuses?
Old 04-18-2014 | 07:23 AM
rellgeta's Avatar
UPDATE.. I have found the problem.. it was an 7.5 amp fuse... wow!!! such a little thing can cause all that crazyness... smh
Old 04-18-2014 | 10:11 AM
ErickUa5's Avatar
Mr.Helpful Diagram
That fuse gave up for a reason, any work done or mods ?
Old 04-18-2014 | 10:17 AM
3.2TLc's Avatar
May have shorted something out during the recent switch replacement ?
Old 04-18-2014 | 10:50 AM
Skirmich's Avatar
What Fuse?? 7.5? Clock fuse? You don't want to being replacing short fuses as they are protecting your wiring.
Old 04-18-2014 | 10:52 AM
rellgeta's Avatar
it wasent the clock fuse.. it was one of them on the drivers side fuse box inside the car..
Old 04-18-2014 | 10:56 AM
rellgeta's Avatar
it made anything inside the car not work except the clock,radio, hvac system... so that must be a major fuse.. i had to drive over 45 miles before checking it ( i know it was dumb...) i hope that fuse didnt control any of the radiator fans.... cause now asfter it was replaced i am feeling studdering on low rpm driving 1-2.. i did the tune up 5 months ago and done everything on the diy section on this fourm... so I guess i messed something up
Old 04-18-2014 | 10:59 AM
Skirmich's Avatar
Have to know what fuse is if possible so we could start diagnosing without guessing.
Old 04-18-2014 | 11:23 AM
Yikes's Avatar
If it blows again, you have a larger problem.
Old 04-18-2014 | 11:37 AM
rellgeta's Avatar
its crazy cause i have not done any mods on this car since i got it.. only thing i replaced "if u call it mod" is the aftermarket radio the last person had in the car..
Old 04-18-2014 | 01:07 PM
rellgeta's Avatar
WELL........ the fuse was the 7.5 acc relay fuse.. first time it ever blew. does that fuse contol engine electrics too? like the fans on the radiator? yes i am very scared if it did.. i had to drive from dallas to ft worth TX (about 45 miles) without seeing anything working on the dash...
Old 04-18-2014 | 01:10 PM
Skirmich's Avatar
OUCH! ACC fuse could well end up being a problem in your Aftermarket Radio installation.
ACC Fuse controls most base voltage level for: Dashboard, A/C, Radio, Ignition, Etc... It doesn't control line level voltage (Thus why its low Amperage) but its basically the master base voltage to control live full 12v Voltage Relays and Stuff.
I would re-check all stuff in your Radio Installation as IF the ACC fuse blow up while driving your car will automatically turn off.
Old 04-18-2014 | 01:25 PM
rellgeta's Avatar
thats crazy lol.. it was funny that it started yesterday like that.. question.. would that fuse control the fans too?? now when the ac or the heater was on for that time the fan cut on.. i drove to my machanic with the heater on blast (90) so the radiator fans would stay on.. i just hope i didnt kill nothing engine wise.. THATS what i am scared of
Old 04-18-2014 | 02:58 PM
Skirmich's Avatar
Its weird because if ACC blows you should not be able to start the car as the Ignition Key should have no power.. BUT I don't know if killing the Ignition will still allow power to run from Key Position II which runs the A/C and can turn on the Fans..
This will be far better explained by an Electrician using the Electric Diagrams.. In any case if you didn't run the car too much don't worry as long as the FANS where on the Engine should had no problem being cooled down.
Old 04-18-2014 | 03:20 PM
rellgeta's Avatar
yea.. i was sweating like a pig in the car when i had to drive it 45 miles with the heat on high and 90...... since the windows was not working too lol..
MilanoRedDashR
10-08-2015 10:30 AM
KBTypeS
25
10-01-2015 04:49 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
TLguy42
09-26-2015 11:27 AM
Quick Reply: Quick help!!!!
